ST asks for login credentials for 127.0.0.1 on Android
Hello folks,
ST is running well on my Android 9.0 smartphone. I can open the web interface within the Synthing app without any problem.
If I try to open 127.0.0.1:8384 locally via the Chrome browser, a login dialog appears, that asks for credentials to access the page. I have not set up any username / password. I even can´t find any settings for that in the Android client.
Why is ST asking for login credentials?
I believe this is a security measure, to prevent other apps on the phone from interacting with syncthing without authorization. The inbuild webview in the app is configured to authenticate automatically.
The username/password used is fixed (username is syncthing, password is the API key).
Thank you, @Nummer378 and @Catfriend1. Login with the API-Key and “syncthing” works. :ok_hand:
