I am using syncthing on a VPS. The name has changed and I also changed the hostname in syncthing. The ssl certificate is not renewed. How can I reset the ssl certificate?
The SSL-Cert is located in ~/.config/syncthing/
. Delete the https-cert.pem
and https-key.pem
while syncthing is not running and it should create a new cert on next startup.
Thanks but it also resets my hostname again
I can now see the old hostname in the title of syncthing and not the new one which I changed in the syncthing options. I again gives me the certificate error “wrong url”
edit: I did a restart and the name in synchting is now correct but the certificate name still points to the old name.
I cleaned up the hosts and set the new hostname correct in the hostname file. Everything is fine now! Thanks!
