2017-02-13 16:07:19: Some protected files may be overwritten and cause issues. See http://docs.syncthing.net/users/config.html#syncing-configuration-files for more information. The at risk files are: /Users//Library/Application Support/Syncthing/index-v0.14.0.db, /Users//Library/Application Support/Syncthing/config.xml, /Users//Library/Application Support/Syncthing/cert.pem, /Users//Library/Application Support/Syncthing/key.pem
So I believe I discovered a bug. When you re-add a share, when you go to enter the path, it will ostensibly autofill the path based on what you typed in the past.
So I entered ~/Users/ and it autofilled the rest of the path. I hit enter, the full path remained in the slot. But when I hit OK and then examined the resultant share, the path was only the portion I had typed manually.
As a result I was syncing my entire user profile directory with my coworkers machine, hence the error.
It seems the autofill is useless and you have to make sure to type the entire path matter what.
Yeah, there was a bug about this a while back in the tracker, but I couldn’t find it now. Basically, the browser doesn’t tell us when it changes the text field based on the autocomplete, so it never reaches Syncthing.
Is there any way to suppress this warning?
Shouldn’t it be suppressed automatically if someone ignored configuration directory in all shared directories which include it?
