I may be missing something, but I am sure I used to be able to connect a folder Manually. All I can see is that folders are created automatically and any folder with contents cannot be connected. This is really annoying. Is there a way to connect a folder manually?
Yes; all you have to do is have matching folder IDs on both sides and check the boxes to share with the relevant devices.
Magick!!! Thanks @calmh So easy when you know how. I had searched high and low in the Docs & Online for this one. Regards
