Hi again!
I would like to know what are the contents of this directory…
~/.config/syncthing/index-v0.14.0.db
I just make a script to take some backup from the home folder but I don’t know if this directory is important.
Hi again!
It’s the “index database” which contains metadata about your files. If you expect to be able to restore your files and your Syncthing config and just keep going you should back it up. If you don’t back up the data Syncthing is syncing you don’t need to back up the index either.
Thanx for the quick response.
