when my app (syncspirit), communicates with syncthing (v1.23.2), syncthing “forgets” download progress.
At the protocol level, my app sends Index message with zero files and non-zero index, and later it sends updates with IndexUpdate. In the UI it shows 100% in sync, however, after my app reconnect it drops to zero.
Here are the logs:
[4QDTF] 2023/03/12 19:27:42.688870 service.go:245: INFO: Peer at 192.168.100.42:22000-192.168.100.42:54171/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 did not negotiate bep/1.0
[4QDTF] 2023/03/12 19:27:42.692460 service.go:423: INFO: Established secure connection to WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH at 192.168.100.42:22000-192.168.100.42:54171/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
[4QDTF] 2023/03/12 19:27:42.692541 indexhandler.go:463: DEBUG: Removing index handler for device WICHSMT and folder default
[4QDTF] 2023/03/12 19:27:42.692557 indexhandler.go:469: DEBUG: Removed index handler for device WICHSMT and folder default
[4QDTF] 2023/03/12 19:27:42.692600 indexhandler.go:549: DEBUG: Not resuming index handler for device WICHSMT and folder lwmfe-w394s as none is paused and there is no start info
[4QDTF] 2023/03/12 19:27:42.692613 indexhandler.go:463: DEBUG: Removing index handler for device WICHSMT and folder vnsfq-njnvr
[4QDTF] 2023/03/12 19:27:42.692620 indexhandler.go:469: DEBUG: Removed index handler for device WICHSMT and folder vnsfq-njnvr
[4QDTF] 2023/03/12 19:27:42.692654 model.go:2265: INFO: Device WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH client is "syncspirit v0.3.0" named "xps" at 192.168.100.42:22000-192.168.100.42:54171/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
[4QDTF] 2023/03/12 19:27:42.693314 model.go:1168: DEBUG: Handling ClusterConfig from WICHSMT
[4QDTF] 2023/03/12 19:27:42.693416 indexhandler.go:73: DEBUG: Device WICHSMT folder "trivial-folder" (lwmfe-w394s) has no index ID for us
[4QDTF] 2023/03/12 19:27:42.693452 indexhandler.go:95: INFO: Device WICHSMT folder "trivial-folder" (lwmfe-w394s) has a new index ID (0xE037171556F3CF96)
[4QDTF] 2023/03/12 19:27:42.693659 indexhandler.go:132: DEBUG: Starting index handler for lwmfe-w394s to WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH at 192.168.100.42:22000-192.168.100.42:54171/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 (slv=0)
[4QDTF] 2023/03/12 19:27:42.693897 indexhandler.go:231: DEBUG: indexHandler@0xc0003b8680 for lwmfe-w394s to WICHSMT at 192.168.100.42:22000-192.168.100.42:54171/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256: Sending 1 files (<148 bytes)
[4QDTF] 2023/03/12 19:27:42.694841 model.go:1129: DEBUG: Index (in): WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH / "lwmfe-w394s": 0 files
[4QDTF] 2023/03/12 19:27:42.736119 model.go:1854: DEBUG: model@0xc000103860 REQ(in): WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH: "lwmfe-w394s" / "hello.txt" o=0 s=32 t=false
[4QDTF] 2023/03/12 19:27:42.739026 model.go:1129: DEBUG: Index update (in): WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH / "lwmfe-w394s": 1 files
[4QDTF] 2023/03/12 19:27:43.689547 progressemitter.go:285: DEBUG: progress emitter: bytes completed for lwmfe-w394s: 0
[4QDTF] 2023/03/12 19:27:43.689817 model.go:928: DEBUG: model@0xc000103860 Completion(WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH, "lwmfe-w394s"): map[completion:100 globalBytes:32 globalItems:1 needBytes:0 needDeletes:0 needItems:0 remoteState:valid sequence:2]
I disconnect, and then
[4QDTF] 2023/03/12 19:27:57.283135 model.go:1783: INFO: Connection to WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH at 192.168.100.42:22000-192.168.100.42:54171/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 closed: closed by remote: peer_supervisor actor shutdown has been requested by supervisor <- net::coodinator actor shutdown has been requested by supervisor <- net::coodinator normal shutdown
[4QDTF] 2023/03/12 19:27:57.283378 indexhandler.go:137: DEBUG: Exiting index handler for lwmfe-w394s to WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH at 192.168.100.42:22000-192.168.100.42:54171/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256: context canceled
[4QDTF] 2023/03/12 19:28:29.305599 service.go:245: INFO: Peer at 192.168.100.42:22000-192.168.100.42:53755/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 did not negotiate bep/1.0
[4QDTF] 2023/03/12 19:28:29.310028 service.go:423: INFO: Established secure connection to WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH at 192.168.100.42:22000-192.168.100.42:53755/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
[4QDTF] 2023/03/12 19:28:29.310103 indexhandler.go:463: DEBUG: Removing index handler for device WICHSMT and folder default
[4QDTF] 2023/03/12 19:28:29.310119 indexhandler.go:469: DEBUG: Removed index handler for device WICHSMT and folder default
[4QDTF] 2023/03/12 19:28:29.310134 indexhandler.go:549: DEBUG: Not resuming index handler for device WICHSMT and folder lwmfe-w394s as none is paused and there is no start info
[4QDTF] 2023/03/12 19:28:29.310146 indexhandler.go:463: DEBUG: Removing index handler for device WICHSMT and folder vnsfq-njnvr
[4QDTF] 2023/03/12 19:28:29.310154 indexhandler.go:469: DEBUG: Removed index handler for device WICHSMT and folder vnsfq-njnvr
[4QDTF] 2023/03/12 19:28:29.310191 model.go:2265: INFO: Device WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH client is "syncspirit v0.3.0" named "xps" at 192.168.100.42:22000-192.168.100.42:53755/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
[4QDTF] 2023/03/12 19:28:29.311167 model.go:1168: DEBUG: Handling ClusterConfig from WICHSMT
[4QDTF] 2023/03/12 19:28:29.311311 indexhandler.go:62: DEBUG: Device WICHSMT folder "trivial-folder" (lwmfe-w394s) is delta index compatible (mlv=5)
[4QDTF] 2023/03/12 19:28:29.311426 indexhandler.go:132: DEBUG: Starting index handler for lwmfe-w394s to WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH at 192.168.100.42:22000-192.168.100.42:53755/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 (slv=5)
[4QDTF] 2023/03/12 19:28:29.352342 model.go:1129: DEBUG: Index (in): WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH / "lwmfe-w394s": 0 files
[4QDTF] 2023/03/12 19:28:29.749422 progressemitter.go:285: DEBUG: progress emitter: bytes completed for lwmfe-w394s: 0
[4QDTF] 2023/03/12 19:28:29.749889 model.go:928: DEBUG: model@0xc000103860 Completion(WICHSMT-QDEQWEA-7ZPOJLT-HHBYCTL-4Q4NWOJ-PSDC7FW-DW7IYEZ-HSBJDQH, "lwmfe-w394s"): map[completion:0 globalBytes:32 globalItems:1 needBytes:32 needDeletes:0 needItems:1 remoteState:valid sequence:0]
The key log info, imho, is:
However, I think I do correctly use bep-proto, and it is valid to send Index with zero-files. Or, may, I did misread something?
I think the same buggy behavior can be achieved, when sharing empty folder, and lately add files in it.
Thanks,
