I use Syncthing to sync my configuration files for, e.g., Emacs, Vimperator, etc. When I have more computers running, sync conflicts arise naturally and have to be resolved. Mostly, those conflicts are about changes in configuration files, or bookmarks and so on.
I wanted to announce a small bash script that I wrote to handle sync conflicts in text files similar to the pacdiff utility from Arch Linux. A diff utility can be used to merge the files and keep them up to date.
This script is not checking for conflicts itself, it uses locate to do so. You can also use find when issuing the -f flag. However, this takes much longer, because there is no pre-populated database to be queried. Of course, we could implement other search engines. Let me know what you think.
Does this answer your question?
EDIT: The conflict resolution is still interactive (and should be interactive) so it is not suitable for a cron job. Finding conflicts, of course, is very much suitable for a cron job. (But doesn’t Syncthing report conflicts anyway, so maybe scraping the log would be better?)
Hello Dominik,
You’re right. But since I would run it not too frequently I wouldn’t be bothered by the couple of seconds it takes, especially since it’s in the background. I just made myself a quick and dirty way. I don’t know too much about syncthing, scripting and the like but it sure seems like there are smarter ways to do this, e.g. sifting through the log. I just don’t know how to do it yet. Because I am not fully able to grasp your script I asked whether it had that functionality. For now I am totally fine with my version though but sure would be happy about pointers on how to read the log. Ideally it would result in a notify-send bringing the conflict to my attention.
