I’ve been researching this issue for a day or 2 and I’ve seen endless posts from people not understanding relaying and not providing any examples of the issue so I’m going to try not to do that and provide all the examples I can to increase my chances of fixing!
I’m running Syncthing as a docker container. It is only 1 of 3 very low resource hungry containers on an i5, 32GB host running Ubuntu Server V23.04. Nothing else runs on this host. I’m using the image provided by LinuxServer.io (syncthing - LinuxServer.io).
The docker container version I’m running is: V1.27.3-ls131 Build-date:- 2024-02-24T01:33:35+00:00
I have a share on my NAS for backing up my Pixel Phone. This share is shared out over NFS. The Ubuntu Server mounts this share at startup over NFS. The Syncthing container then maps to the folders within this mount point as so:
syncthing:
container_name: syncthing
image: lscr.io/linuxserver/syncthing:latest
restart: unless-stopped
hostname: syncthing
volumes:
- ./syncthing/config:/config
- /mnt/nfs/pixel_backups/Apps/Signal:/Signal-Backups
- /mnt/nfs/pixel_backups/Apps/Aegis:/Aegis-Backups
- /mnt/nfs/pixel_backups/Photos:/Photos-Backups
ports:
- "8007:8384"
- "22000:22000/tcp"
- "22000:22000/udp"
- "21027:21027/udp"
environment:
- PUID=1000
- PGID=1000
- TZ=Etc/UTC
I have disabled Compression and relaying on both ends.
My Pixel device is running the latest version of Syncthing. I have linked the Pixel Phone to the server via the scanning of the QR code.
The device showing in the server side console shows that the device is connected over: TCP WAN, port 22000, with compression off.
I have run iperf in a docker container so that I can confirm that it is not the docker layer that is slowing the transfer speed. Tests from the phone to the iperf Docker container shows the following results on the iperf3 docker container:
Server listening on 5201 (test #1)
Accepted connection from 192.168.100.237, port 52644
[ 5] local 172.18.0.8 port 5201 connected to 192.168.100.237 port 52648
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 512 KBytes 4.19 Mbits/sec
[ 5] 1.00-2.00 sec 512 KBytes 4.19 Mbits/sec
[ 5] 2.00-3.00 sec 512 KBytes 4.19 Mbits/sec
[ 5] 3.00-4.00 sec 512 KBytes 4.19 Mbits/sec
[ 5] 4.00-5.00 sec 512 KBytes 4.19 Mbits/sec
[ 5] 5.00-5.05 sec 128 KBytes 21.4 Mbits/sec
[ 5] 0.00-5.05 sec 2.62 MBytes 4.36 Mbits/sec receiver
So clearly I can get Mbps transfer speed with this setup.
However, what I am seeing is a download rate of: 568 KiB/s and upload of 33 B/s.
I cannot think, nor find any other posts, of what else I can try to resolve this issue.
If anyone has any suggestions, I’d happily take them as this tool is a million times better than having to build another Nextcloud server just to back up my phone to my NAS!
