Hi ![]()
Problem:
- I’m experiencing a very slow sync since a while (only “One” textfile of “50kb” in "2-5"sec), although bigger files are sync way faster. Good speed. Couldn’t figure out what to do and reached a point where i would have to start getting a degree as a network admin first (it feels). → I’m desperate, and hope to find support by stronger souls here.
Devices:
- PC: Windows 11 (syncthing v1.25.0 “Gold Grasshopper”)
- Phone: Android 13 Samsung Galaxy S20 FE (syncthing v1.23.7)
- Router: FritzBox Cable 6660 (FRITZ!OS: 7.57)
System:
- The PC is connected to the FritzBox with a LAN cable (into the LAN1 slot of the router).
- Performance of CPU is <5% while syncing
- The Phone is connected to the router with WiFi 6, 2.5GHz.
- Performance of CPU is 0% while syncing
Situation at the moment:
- Both Devices (PC and Phone) are connected
- and a folder is set up as “shared”
- The folder has only textfiles (25.000).
- Connection is via TCP LAN (Phone: 192.168.178.22:22000, PC: 192.168.178.46:22000)
- Compression is off, on both devices
PC Settings:
- Windows 10: In a Private Network (before it was Public, but speed didnt change with beeing in a private one)
- Syncthing: adress for sync protocol: default
- Syncthing: data rate limit: 0
- Syncthing: NAT: off (was on before, no change, its the same speed)
- Syncthing: local search: on
- Syncthing: global search: on (was off before, no change, its the same speed)
- server for global search: default
- Syncthing: relay: off
Phone Settings:
- same as PC
PC Log:
- 2023/11/02 09:46:26 INFO: Single thread SHA256 performance is 2082 MB/s using crypto/sha256 (2059 MB/s using minio/sha256-simd).
- 2023/11/02 09:46:27 INFO: Hashing performance is 1318.80 MB/s
- 2023/11/02 09:46:27 INFO: Overall send rate is unlimited, receive rate is unlimited
- 2023/11/02 09:46:27 INFO: Using discovery mechanism: global discovery server https ://discovery.syncthing.net/v2/?noannounce&id=…
- 2023/11/02 09:46:27 INFO: Using discovery mechanism: global discovery server https ://discovery-v4.syncthing.net/v2/?nolookup&id=…
- 2023/11/02 09:46:27 INFO: Using discovery mechanism: global discovery server https ://discovery-v6.syncthing.net/v2/?nolookup&id=…
- 2023/11/02 09:46:27 INFO: Using discovery mechanism: IPv4 local broadcast discovery on port 21027
- 2023/11/02 09:46:27 INFO: Using discovery mechanism: IPv6 local multicast discovery on address … …
- 2023/11/02 09:46:27 INFO: QUIC listener ([::]:22000) starting
- 2023/11/02 09:46:27 INFO: TCP listener ([::]:22000) starting …
- 2023/11/02 09:47:11 INFO: Established secure connection to … at 192.168.178.46:22000-192.168.178.22:22000/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-…-…
- 2023/11/02 09:47:11 INFO: Device … client is “syncthing v1.23.7” named “…” at 192.168.178.46:22000-192.168.178.22:22000/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-…-…
Ports:
- I was reading so much that opening the ports on the windows machine didn’t change anything.
- Also, i am overwelmed by the settings and options and adresses and numbers… its too much for me.
- internal ports, external ports, routersettings, pc settings, and on and on.
