I have a problem with the synchronization of some files that I have shared between my pc, my vps and my mobile. Between the PC and VPS everything is fine but sometimes on the mobile I get “Skip changes” and then the files are deleted from the other devices so that this all the same and therefore I lose the changes.
I suspect your mobile folder is shared in sendOnly mode. Try sendReceive.
Yes, that was the problem, thank you very much bro
