setup initialization error: WSH script registration is not valid
hi there. i just want to install sycnthing on my windows computer. but it shows this error
"setup initialization error: WSH script registration is not valid
to correct this issue, please see the ‘setup initialization errors’ section in the documentation
setup will now exit"
I have checked the documentation, but no luck. i can’t even found the article
could you guys please help me with this. thank you
The official Syncthing package for Windows doesn’t have an installer and/or use WSH, so most likely you’re using @billstewart’s setup tool. Here’s the documentation for it:
i found the solution
thank you so much @gadget
