Set max conflicts globally
Hi :), Please tell me it’s possible to disable the max conflicts setting globally. I have way too many folders on many different devices to set it for every single one of them to zero…
You need to set it on each and every one.
(Or use some sort of search/replace on the config.)
Thanks for the reply! Do I have to edit the config file for each device or is it enough to do it for my main device?
This setting, like essentially all others, is local to the device where it’s done. If you want conflict files to not be created on a given device, you need to configure it there.
Very unfortunate… But thanks for the fast clarification!
