HeavCyb
#1
Hello,
I try to set up a relay but I have an error message:
“listener failed to accept Connection from . Possibly has TCP ping.”
I already have a port redirection for 22067 and 22070 on my machine and firewall is already configuring …
In addition, I also have an error message:
“Protocol Negociation Error”
and
“Certificate List Error”
What to do ?
Config:
Windows 10 x64
Internet connection: 1GB/s fiber optic
Provider: Free (French Provider)
Firewall: TinyWall (Software from https:// tinywall.pados.hu)
Content of the .bat file
“StrelaySRV -Debug -Global-Rate = 100000000 -Status-SRV = 0.0.0.0: 22070”
Note:
English is not my primary language (I’m French)
calmh
(Jakob Borg)
#2
Some of those errors are not errors, but shown due to -debug
, I think. Show a full log and maybe we can draw some conclusions.
HeavCyb
#3
Hello,
Here my log (if it’s what you need)
C:\strelaysrv-windows-amd64-v1.15.0>strelaysrv -debug
2021/12/01 13:01:59 main.go:140: strelaysrv v1.15.0 "Fermium Flea" (go1.16.3 windows-amd64) teamcity@build.syncthing.net 2021-04-06 06:03:22 UTC
2021/12/01 13:01:59 main.go:185: ID: IIAV5BQ-6W2VAHK-G6UGJMB-IAO7FGA-6UYOSOZ-BLJTRQZ-AMVAJGP-DKYJBQT
2021/12/01 13:01:59 main.go:239: URI: relay://0.0.0.0:22067/?id=IIAV5BQ-6W2VAHK-G6UGJMB-IAO7FGA-6UYOSOZ-BLJTRQZ-AMVAJGP-DKYJBQT&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=
2021/12/01 13:01:59 main.go:242: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2021/12/01 13:01:59 main.go:243: !! Joining default relay pools, this relay will be available for public use. !!
2021/12/01 13:01:59 main.go:244: !! Use the -pools="" command line option to make the relay private. !!
2021/12/01 13:01:59 main.go:245: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2021/12/01 13:01:59 pool.go:22: Joining https://relays.syncthing.net/endpoint
2021/12/01 13:01:59 listener.go:40: Listener failed to accept connection from 217.155.16.109:34210 . Possibly a TCP Ping.
2021/12/01 13:01:59 listener.go:40: Listener failed to accept connection from 103.192.205.132:46535 . Possibly a TCP Ping.
2021/12/01 13:01:59 listener.go:40: Listener failed to accept connection from 69.75.177.238:49732 . Possibly a TCP Ping.
2021/12/01 13:01:59 listener.go:40: Listener failed to accept connection from 185.242.5.158:46149 . Possibly a TCP Ping.
2021/12/01 13:01:59 listener.go:40: Listener failed to accept connection from 45.15.18.2:47205 . Possibly a TCP Ping.
2021/12/01 13:01:59 listener.go:40: Listener failed to accept connection from 23.126.187.242:42175 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 68.37.53.208:38370 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 177.43.10.13:43420 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 84.193.112.169:58446 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 190.141.58.77:33724 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 85.221.253.201:40098 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:48: Listener accepted connection from 82.196.13.137:38172 tls true
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 209.161.39.185:44658 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:48: Listener accepted connection from 82.196.13.137:38174 tls true
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 184.147.80.240:34145 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 92.40.191.202:64680 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:117: Message protocol.JoinRelayRequest from TSCVLSJ-HFWYE6E-DIZIW6L-SJWOK3O-SBX5ERY-IMCCGNA-4ZUEFXJ-HQJVWQW
2021/12/01 13:02:00 listener.go:117: Message protocol.ConnectRequest from TSCVLSJ-HFWYE6E-DIZIW6L-SJWOK3O-SBX5ERY-IMCCGNA-4ZUEFXJ-HQJVWQW
2021/12/01 13:02:00 session.go:54: New session <d3ef7/74bc0>
2021/12/01 13:02:00 session.go:135: Session <d3ef7/74bc0> serving
2021/12/01 13:02:00 listener.go:191: Sent invitation from TSCVLSJ-HFWYE6E-DIZIW6L-SJWOK3O-SBX5ERY-IMCCGNA-4ZUEFXJ-HQJVWQW to TSCVLSJ-HFWYE6E-DIZIW6L-SJWOK3O-SBX5ERY-IMCCGNA-4ZUEFXJ-HQJVWQW
2021/12/01 13:02:00 listener.go:281: Sending message protocol.SessionInvitation to TSCVLSJ-HFWYE6E-DIZIW6L-SJWOK3O-SBX5ERY-IMCCGNA-4ZUEFXJ-HQJVWQW
2021/12/01 13:02:00 listener.go:223: Closing connection TSCVLSJ-HFWYE6E-DIZIW6L-SJWOK3O-SBX5ERY-IMCCGNA-4ZUEFXJ-HQJVWQW: read tcp 192.168.1.15:22067->82.196.13.137:38172: use of closed network connection
2021/12/01 13:02:00 listener.go:223: Closing connection TSCVLSJ-HFWYE6E-DIZIW6L-SJWOK3O-SBX5ERY-IMCCGNA-4ZUEFXJ-HQJVWQW: EOF
2021/12/01 13:02:00 listener.go:48: Listener accepted connection from 162.241.149.10:60162 tls true
2021/12/01 13:02:00 pool.go:74: Joined pool https://relays.syncthing.net/endpoint, rejoining in 48m0s
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 78.80.105.88:1641 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 37.160.159.0:62736 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 217.250.43.162:43906 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 181.44.116.33:23423 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 185.177.73.174:45510 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 90.43.180.195:26955 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 86.56.240.113:57677 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 188.176.134.46:38054 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:48: Listener accepted connection from 187.161.144.201:8351 tls true
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 181.29.208.2:44690 . Possibly a TCP Ping.
2021/12/01 13:02:00 listener.go:40: Listener failed to accept connection from 72.238.98.196:46174 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:72: Protocol connection TLS handshake: 187.161.144.201:8351 read tcp 192.168.1.15:22067->187.161.144.201:8351: wsarecv: Une connexion existante a dû être fermée par l’hôte distant.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 195.13.40.70:10583 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 176.146.224.38:44660 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 177.38.112.157:39549 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:48: Listener accepted connection from 187.161.144.201:4808 tls true
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 87.205.8.168:28613 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:72: Protocol connection TLS handshake: 187.161.144.201:4808 read tcp 192.168.1.15:22067->187.161.144.201:4808: wsarecv: Une connexion existante a dû être fermée par l’hôte distant.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 31.173.243.183:7076 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 107.171.201.236:38370 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 85.221.253.201:38464 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 54.147.148.57:49897 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 191.34.135.54:34158 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 12.215.195.18:49940 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 41.243.40.179:16721 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 67.60.223.54:55831 . Possibly a TCP Ping.
2021/12/01 13:02:01 listener.go:40: Listener failed to accept connection from 90.49.51.127:56642 . Possibly a TCP Ping.
2021/12/01 13:02:02 listener.go:40: Listener failed to accept connection from 185.171.178.216:23731 . Possibly a TCP Ping.
2021/12/01 13:02:02 listener.go:40: Listener failed to accept connection from 89.238.150.171:53964 . Possibly a TCP Ping.
2021/12/01 13:02:02 listener.go:40: Listener failed to accept connection from 195.72.110.80:10403 . Possibly a TCP Ping.
2021/12/01 13:02:02 listener.go:40: Listener failed to accept connection from 162.229.182.244:60685 . Possibly a TCP Ping.
2021/12/01 13:02:02 listener.go:40: Listener failed to accept connection from 121.200.7.147:6210 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 188.170.74.203:15649 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 64.183.54.182:49875 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 117.131.85.56:57084 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 196.189.57.12:5285 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 182.170.169.63:50404 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 185.191.99.5:50326 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 78.54.247.102:52892 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 89.238.150.171:59666 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 95.223.74.93:58750 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 201.252.107.54:45200 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 178.168.48.3:58459 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 176.36.19.207:54546 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 77.189.106.107:56424 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 188.26.212.252:41396 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 212.95.5.150:43665 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 178.183.153.99:62398 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 195.113.242.140:48644 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 185.193.143.63:49278 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 98.208.201.32:60243 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 77.21.62.206:62073 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 151.57.115.16:5469 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 86.91.98.209:49220 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 156.67.173.37:37209 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 46.159.171.47:49266 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 125.86.164.250:4037 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 103.192.205.132:41265 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 91.73.81.23:10403 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 79.131.238.171:35910 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 138.229.55.119:43222 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 83.56.34.64:57397 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 98.44.204.192:64550 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 188.11.202.168:51401 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 37.120.217.84:51270 . Possibly a TCP Ping.
2021/12/01 13:02:03 listener.go:40: Listener failed to accept connection from 134.101.148.15:49809 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 86.29.209.95:50588 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 71.9.145.221:62169 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 67.220.173.78:49935 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 87.132.88.145:35158 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 92.255.220.9:55198 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 78.36.137.29:39966 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 80.144.183.2:40648 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 217.92.189.146:51873 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 89.8.88.240:57018 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 5.130.30.18:55154 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 84.193.112.169:58476 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 74.96.221.13:50127 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 98.162.171.115:1181 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 74.96.221.13:50129 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 87.110.40.135:57546 . Possibly a TCP Ping.
2021/12/01 13:02:04 listener.go:40: Listener failed to accept connection from 83.56.34.64:53679 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 84.26.88.72:60838 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 124.108.22.162:53966 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 49.207.225.158:10374 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 45.79.178.30:41458 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 78.36.137.29:37772 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 37.201.198.100:29521 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 45.79.178.30:49176 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 148.170.122.144:51352 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 103.164.81.16:65042 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 165.227.171.144:33762 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 24.193.1.102:49915 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 109.129.30.171:54239 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 213.138.162.211:57096 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 112.87.177.140:47079 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 195.113.242.140:57752 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 177.240.161.73:1942 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 92.255.220.9:55108 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 196.191.48.33:28181 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 103.164.81.16:62356 . Possibly a TCP Ping.
2021/12/01 13:02:05 listener.go:40: Listener failed to accept connection from 91.235.246.41:60826 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 195.3.246.174:49939 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 102.252.66.248:22863 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 90.30.247.69:49220 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 62.216.211.101:30296 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 89.109.206.222:34938 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 113.230.112.41:40087 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 80.187.116.100:16497 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 46.211.109.72:4614 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 131.255.8.62:50343 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 65.92.204.217:38832 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 91.89.177.246:4528 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 46.114.169.160:35968 . Possibly a TCP Ping.
2021/12/01 13:02:06 listener.go:40: Listener failed to accept connection from 94.31.90.35:45016 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 101.80.97.184:56044 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 5.142.46.107:4692 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 83.56.34.64:53702 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 82.217.108.164:35836 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 105.225.252.234:64878 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 177.131.178.111:57004 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 5.151.22.243:43710 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 91.58.128.247:38437 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 109.200.151.4:37020 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 118.113.39.36:4992 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 178.13.104.68:63896 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 24.4.149.9:60662 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 38.27.142.185:51649 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 94.198.43.58:37434 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 118.209.91.111:38606 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 120.244.232.61:21181 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 109.167.219.12:51512 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 113.87.248.230:9413 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 180.183.152.62:61991 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 173.198.119.130:49749 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 86.56.240.113:57764 . Possibly a TCP Ping.
2021/12/01 13:02:07 listener.go:40: Listener failed to accept connection from 179.154.236.80:60110 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 79.129.154.205:1628 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 138.229.55.119:49178 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 85.117.104.6:57215 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 212.159.26.42:42948 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 104.187.178.243:40799 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 77.21.153.91:53556 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 97.107.62.60:63570 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 153.154.9.61:40048 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 37.122.102.236:49864 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 5.130.30.18:52858 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 179.154.236.80:48255 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 116.203.222.18:48608 . Possibly a TCP Ping.
2021/12/01 13:02:08 listener.go:40: Listener failed to accept connection from 67.42.94.123:37562 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 216.228.192.26:44946 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 92.63.47.251:50459 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 178.249.51.108:52626 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 104.187.178.243:29595 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 81.173.200.62:42697 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 195.3.246.174:40594 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 67.60.223.54:55870 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 80.144.183.2:41657 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 76.171.138.182:55350 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 223.66.228.77:34081 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 146.0.115.137:34902 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 195.3.246.174:40600 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 223.33.165.73:58392 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 93.193.22.254:49734 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 222.29.102.73:56318 . Possibly a TCP Ping.
2021/12/01 13:02:09 listener.go:40: Listener failed to accept connection from 5.81.248.29:36229 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 91.200.115.171:47735 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 31.173.82.156:46601 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 176.222.228.253:52036 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 185.193.143.63:53730 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 173.92.164.74:62895 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 160.13.82.137:54127 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 95.91.232.228:21548 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 70.185.56.136:18921 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 178.36.195.174:57081 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 18.197.244.178:35890 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 70.185.56.136:62375 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 92.60.39.86:43522 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 37.160.159.0:62839 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 72.74.50.100:50574 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 93.174.228.186:50112 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 97.107.62.60:63585 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 217.252.198.145:38522 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 183.172.188.255:55168 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 41.210.147.99:41085 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 31.173.86.217:46392 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 185.191.99.5:50438 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 24.182.189.236:56162 . Possibly a TCP Ping.
2021/12/01 13:02:10 listener.go:40: Listener failed to accept connection from 31.3.73.150:34766 . Possibly a TCP Ping.
2021/12/01 13:02:11 listener.go:40: Listener failed to accept connection from 178.249.51.108:40598 . Possibly a TCP Ping.
2021/12/01 13:02:11 listener.go:40: Listener failed to accept connection from 182.170.169.63:40140 . Possibly a TCP Ping.
2021/12/01 13:02:11 listener.go:40: Listener failed to accept connection from 92.207.233.82:51011 . Possibly a TCP Ping.
2021/12/01 13:02:11 listener.go:40: Listener failed to accept connection from 91.232.158.3:49187 . Possibly a TCP Ping.
2021/12/01 13:02:11 listener.go:40: Listener failed to accept connection from 5.81.248.29:9041 . Possibly a TCP Ping.
2021/12/01 13:02:11 listener.go:40: Listener failed to accept connection from 178.70.119.218:43069 . Possibly a TCP Ping.
calmh
(Jakob Borg)
#4
Relay appears to do what it’s supposed to, since there are incoming connections that are accepted in the log.
HeavCyb
#5
So, for you, my setup work fine ?
No additional config to do ?
system
(system)
closed
#6
