Hi everyone,
I’ve implemented a small feature I was missing: an optional per-folder
Scheduled Scan Times setting. Instead of only a fixed periodic
Full Rescan Interval (or real-time watching), you can give a folder a
list of clock times (e.g. 04:00, 12:00, 16:00) and it will only do its
periodic full rescan at those times each day. It doesn’t touch “Watch for
Changes” at all — that keeps working exactly as before.
My concrete use case: a video production workload with very large files (hundreds of GB to low TB per folder), where Syncthing is used as the backup/sync layer for the footage archive. During working hours the connection is needed for other things, so a folder that’s constantly watching and periodically doing full rescans of that much data competes for bandwidth exactly when it’s least wanted. With this feature I can confine that activity to specific off-peak hours (e.g. overnight) instead of it running on a fixed interval all day long.
Code + a short write-up of the changes (config, model scheduler, GUI field)
is here, as a compare against main:
It’s built on top of v2.1.6-rc.3 (2 commits on top, nothing else changed),
has unit tests for the scheduling logic, and I’ve had it running on a real
production instance for the last couple of days (two sendonly folders,
~50k files combined) — both folders have triggered their scheduled scan
exactly on time each night, with zero errors.
I tried to open a pull request the normal way, but I’m getting: “An owner of this repository has limited the ability to open a pull request to users that are collaborators on this repository.” I understand that’s very likely there to deal with low-effort/AI-spam PRs, which is completely reasonable — just wanted to flag it here in case there’s a preferred way to get this in front of a maintainer in the meantime, or a rough idea of when that limit might lift.
Happy to adjust anything about the approach — naming, whether it should interact with the rescan interval differently, etc. Thanks for looking!
