Scan Progress > 100%
Not sure how this happened. The files being scanned are very large, but I haven’t seen this before. Running the docker container on Synology.
2024-04-12 02:59:36 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 227505039243/138347585508 at 48.5 MiB/s (164%) 2024-04-12 02:59:38 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 227605702539/138347585508 at 48.5 MiB/s (164%) 2024-04-12 02:59:40 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 227689588619/138347585508 at 48.2 MiB/s (164%) 2024-04-12 02:59:42 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 227790251915/138347585508 at 48.2 MiB/s (164%) 2024-04-12 02:59:44 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 227874137995/138347585508 at 47.9 MiB/s (164%) 2024-04-12 02:59:46 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 227974801291/138347585508 at 47.9 MiB/s (164%) 2024-04-12 02:59:48 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 228075464587/138347585508 at 47.9 MiB/s (164%) 2024-04-12 02:59:50 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 228192905099/138347585508 at 47.9 MiB/s (164%) 2024-04-12 02:59:52 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 228310345611/138347585508 at 47.9 MiB/s (165%) 2024-04-12 02:59:54 walker/hiqub-gkftd@0xc00490c840: Walk hiqub-gkftd [] current progress 228427786123/138347585508 at 48.4 MiB/s (165%)
The files were created on the Synology and I moved them and renamed them while the scanner had been scanning them, but it should just have restarted the scan. 150% scan progress shouldn’t happen.
The bar was showing 150% and the blue was extending to the right past the box. The scan completed and the bar is back to normal before I could grab a screenshot.
So what happens here is that scan-with-percentage entails two passes: one to sum the size of files that will be scanned, and one more to actually do it. If new things show up between the two I can see the resulting percentage going above a hundred. :slight_smile:
