runtime.asmstdcall()
Had this started to appear on different PCs (1.27.1 rc1)…
[NAGDY] 2023/12/08 20:19:19 INFO: TCP listener ([::]:22000) shutting down
[NAGDY] 2023/12/08 20:19:19 INFO: Exiting
Exception 0xc0000005 0x8 0x0 0x0
PC=0x0 runtime.asmstdcall()
runtime/sys_windows_amd64.s:65 +0x75 fp=0x22fca0 sp=0x22fc80 pc=0x473dd5
rax 0x0
rbx 0x1a27f20
rcx 0x1a88240
rdi 0x7fffffdd000
rsi 0x22fea0
rbp 0x22fde0
rsp 0x22fc78
r8 0x0
r9 0x22fee0
r10 0x1a59a38
r11 0x21
r12 0x22fec0
r13 0x1
r14 0x1a27480
r15 0x0
rip 0x0
rflags 0x10293
cs 0x33
fs 0x53
gs 0x2b
Full trace might help, possibly, but I’m inclined to suspect things like antivirus…
It’s up to four this morning. Only one has anti virus, windows defender. The rest are on old servers.
Don’t know if it helps, but it seems to be on devices that are based on Windows 7 / Server 2008r2 (all backup servers, not production). So wonder if it’s calling a dll that’s no longer supported. I checked a W11 St and that was fine
For the record, Go dropped Windows 7 support in 1.21.
Go 1.20 is the last release that will run on any release of Windows 7, 8, Server 2008 and Server 2012. Go 1.21 will require at least Windows 10 or Server 2016.
Source: https://tip.golang.org/doc/go1.20
I suspected this will be the case, I just rolled all the devices back to 1.27 and they are fine. Unfortunately i’m stuck with these older ones, mainly because they are repurposed machines and only have the one job, to read only network files and sync them to me.
