Hi everybody,
I recently purchased a $20 Pogoplug, because I heard it could run Arch Linux, and I wanted to try setting up a really cheap Syncthing server. Now, this obviously is a low-resource environment, and I’ve had some problems with Syncthing.
What I’m getting is connections opening and closing, because the device is slow. It’ll connect to another node, and then within a minute or so, it’ll close the connection with a ping timeout or a connection reset by peer. Obviously, this severely impacts syncing.
In order to conserve resources, I’ve installed syncthing-inotify and have set the rescan intervals all to 0. This should turn off all scanning, correct?
Now I’m getting this in the syncthing-inotify logs:
Oct 19 15:20:15 K7 syncthing-inotify[231]: [WARNING] Cannot connect to Syncthing: Get http://0.0.0.0:8384/rest/404: dial tcp 0.0.0.0:8384: connection refused
Oct 19 15:21:07 K7 syncthing-inotify[231]: [OK] Watching afc-share: /share/afc-share
Oct 19 15:21:13 K7 syncthing-inotify[231]: [OK] Watching config: /share/config
Oct 19 15:21:13 K7 syncthing-inotify[231]: [OK] Watching julia-movies: /share/julia-movies
Oct 19 15:21:13 K7 syncthing-inotify[231]: [OK] Watching mobile-docs: /share/mobile-docs
Oct 19 15:21:13 K7 syncthing-inotify[231]: [OK] Watching stories: /share/stories
Oct 19 15:21:13 K7 syncthing-inotify[231]: [OK] Syncthing is indexing change in julia-movies: [.stfolder]
Oct 19 15:21:13 K7 syncthing-inotify[231]: [OK] Syncthing is indexing change in stories: [.stfolder]
Oct 19 15:21:14 K7 syncthing-inotify[231]: [OK] Syncthing is indexing change in mobile-docs: [.stfolder]
Oct 19 15:21:15 K7 syncthing-inotify[231]: [OK] Watching pictures: /share/pictures
Oct 19 15:21:16 K7 syncthing-inotify[231]: [OK] Watching personal: /share/personal
Oct 19 15:21:20 K7 syncthing-inotify[231]: [OK] Watching music: /share/music
Oct 19 15:21:20 K7 syncthing-inotify[231]: [OK] Watching learn-share: /share/learn-share
Oct 19 15:21:20 K7 syncthing-inotify[231]: [OK] Watching docs: /share/docs
Oct 19 15:21:21 K7 syncthing-inotify[231]: [OK] Syncthing is indexing change in learn-share: [.stfolder]
Oct 19 15:21:40 K7 syncthing-inotify[231]: [OK] Syncthing is indexing change in docs: [.stfolder]
Oct 19 15:21:44 K7 syncthing-inotify[231]: [OK] Syncthing is indexing change in afc-share: [.stfolder]
Oct 19 15:24:14 K7 syncthing-inotify[231]: [WARNING] Failed to perform request Post http://0.0.0.0:8384/rest/db/scan?folder=config&next=3600&sub=.stfolder: read tcp 127.0.0.1:8384: use of closed network connection
Oct 19 15:24:15 K7 syncthing-inotify[231]: [WARNING] Failed to perform request Post http://0.0.0.0:8384/rest/db/scan?folder=pictures&next=3600&sub=.stfolder: read tcp 127.0.0.1:8384: use of closed network connection
Oct 19 15:24:17 K7 syncthing-inotify[231]: [WARNING] Failed to perform request Post http://0.0.0.0:8384/rest/db/scan?folder=personal&next=3600&sub=.stfolder: read tcp 127.0.0.1:8384: use of closed network connection
Oct 19 15:24:20 K7 syncthing-inotify[231]: [WARNING] Failed to perform request Post http://0.0.0.0:8384/rest/db/scan?folder=music&next=3600&sub=.stfolder: read tcp 127.0.0.1:8384: use of closed network connection
Anybody have any other ideas I can try to get this going? Thanks!
