Rewt0r
(Michael Jephcote)
November 25, 2014, 4:43pm
1
Our server has been setup as in here: Getting Syncthing running with a central file server running CentOS 7 minimal setup and windows clients
Set up this way SYncthing doesn’t produce any log, we can only get recent output using systemctl status syncthing@<username>
It only logs to a file on Windows due to poor pipe support.
On other distros, it’s up to you to set up the right plumbing, log rotation and so on.
Just add >> syncthing.log to the command.
Rewt0r
(Michael Jephcote)
November 25, 2014, 5:36pm
3
Ahh I didn’t reallise that was only done for Windows. Would it be a possibility to add an option to specify a log path that would log to there no matter what OS you’re on?
Read through: (actually its http://adam.herokuapp.com/past/2011/4/1/logs_are_streams_not_files/ )
https://github.com/syncthing/syncthing/issues/411
We make an exception for Windows as it doesn’t have logging daemons like all other OS’es.
Rewt0r
(Michael Jephcote)
November 25, 2014, 5:51pm
5
After reading through that GitHub issue - I agree with the current approach… as you say it’s a non-issue.
Cheers
