I’ve just recently discovered Syncthing and it looks awesome: p2p, discovery and in Go <3 First of all, thanks for all the work you are putting into this open-source project!
I am building a tool where I would need to programatically add/remove directories to Syncthing. Hence my question, is there a way to disable GUI but still use an API? I am guessing not (since same app provides an API?), but just wanted to confirm. But is it possible to build and distribute Syncthing without GUI related implementation at all?
So far I tried adding folders directly to configuration file, but it looks like they don’t have an effect, until I restart Syncthing on all nodes in a cluster. My next question, is it possible to trigger restart programmatically (like sending some signal?), without GUI/API? All I am after is managing Synchthing without GUI.
Cheers.
