I was started to use Syncthing 6 days ago and I checked usage and I must say It was pretty nice to use on my own PC,Phone,Rs-pi all connected. But my main system Fedora so I created a github repository and put “spec” “RPMs” “SRPMS” and how to use it. It’s similar on OpenSUSE repository but I made more detailed SPEC file so we can easily create for separate arch.
I also put SRPM files too but It’s kinda different because of I’m also gonna make repository and getting files from github somehow It’s not working so I changed for now but RPMs are working fine I hope it will be useful for other Fedora users too. And in short time I will be add repository link to and make it more easier to install it.
Since Syncthing is a system binary it can’t be upgraded from web interface and also we are using Systemd to enable/disable/start/stop/restart it what happens when I click Shutdown or Restart from the web interface. Are Shutdown or Restart from the web interface honored by Syncthing installed through COPR repo?
Hello @donniezazen first sorry for late answer and build I was in hospital. Now I’m back to my laptop and build started already. For controlling If you wanna shutdown or restart you need to do that over “systemd” service and when you click that button It’s do nothing because of permission on system (user-root relationship) and
For this point If you update It will be update version restart service and you good to go.
Last Note : COPR build started It will be in very very soon and you will have updated version too. Sorry for delaying
If you add the ‘Restart=always’ line in the systemd service file, you can still restart Syncthing from the web GUI without having to manually restart the service. Shutdown still has be via systemctl, however.
