The location should either be $XDG_STATE_HOME/syncthing or $HOME/.local/state/syncthing. Please keep in mind that the .local folder may be hidden by default in your file manager, so make sure to “show hidden files and folders” (if there is such an option available).
Thank you that solved it, so it was 1:00 AM and I thought there was meant to be a folder named “$XDG_STATE_HOME”, on top of that I did not check the .local folder. Found the .config at “/home/public/.local/state/syncthing/”.
