I run Linuxserver image but today some folders are out of sync so I need to recreate database but I’m not able to use the right command. I tried docker run lscr.io/linuxserver/syncthing -reset-database -reset-deltas
but doesn’t work. Anybody know how can I do?
I don’t think you can do that easily with their Docker image, but you could ask them. With our Docker image, what you’re trying should work.
