So I have a one-way sync setup in which I have a folder on my android which is set to send only and I have selected the option to ignore deletes on the PC to which it is synced to. Now the thing is that whenever I rename a file or folder on my android device then, it creates a clone or the file or folder instead of renaming it on the PC. Is there any way to stop it from creating clones and renaming the files that are changed?
No, because rename is essentially delete and create protocol wise.
