Remote devices stuck syncing
Got this state since a few days. A possible cause I could imagine is that I deleted the database of another device which had all the folder contents (reinstalled windows, data was on external disk, device id stayed the same since I had a backup of the certificate).
No ignore patterns are involved and logs show no errors.
Screenshot:
Example of remote device (looks similar on all devices, folder list not complete but all are “Up to Date”):
data from “alex-uni”
rest/db/completion?device=id-of-raspberrypi2&folder=cloud
   "completion" : 99.7342403616233,
   "needBytes" : 3056405,
   "globalBytes" : 1150063651
rest/db/status?folder=cloud
   "state" : "idle",
   "globalFiles" : 1999,
   "inSyncFiles" : 1999,
   "ignorePatterns" : false,
   "inSyncBytes" : 1150063651,
   "localDeleted" : 42,
   "globalDeleted" : 62,
   "globalBytes" : 1150063651,
   "version" : 370093,
   "invalid" : "",
   "localBytes" : 1150061091,
   "needBytes" : 0,
   "sequence" : 370093,
   "stateChanged" : "2016-08-29T09:05:55.043560745+02:00",
   "localFiles" : 1999,
   "needFiles" : 0
data from “raspberrypi2”:
rest/db/completion?device=id-alex-uni&folder=cloud
   "localBytes" : 1150063651,
   "state" : "idle",
   "sequence" : 696439,
   "invalid" : "",
   "needBytes" : 0,
   "localDeleted" : 62,
   "stateChanged" : "2016-08-29T08:47:39.717556058+02:00",
   "version" : 696439,
   "needFiles" : 0
Interesting. Looks like a bug…
Since synchronization still works I will keep it in this state for now and not nuke the index which could solve it.
What I forgot in the first post: I have several device with exactly the same problems so this bug seems to be “synchronized” in some way.
Should I run with some STTRACE active and post logs?
Hi I meet the same behaviour, but on a single device pair, other devices seem ok. I may also provide information if helpfull.
Nuked delta index by setting config version back to 15 on one device (alex-uni) and it is also gone on another device that is not even connected directly to that one, weird stuff…
I will see if the other 2 devices that showed the same also got fixed by that as soon as I am home. Should I save the database before connecting them for analyzing what is wrong there or save some logs with some STTRACE active when connecting (and potentially fixing it being stuck)?
