After my last problem has been fixed in the last rc (6, thanks again for the fast fix!) I encounter another strange thing. Scenario is as follows:
- Trusted Devices A, B and C, Untrusted Device U, all devices on 1.15.0-rc.6
- New Folder on Device A gets synced to B and U without Issue.
- Now I also want to Sync that folder between B and U directly.
This does work, however the Remote Device Status on U behaves strangely: The more is synced between B and U, the less percent of sync is shown for remote Device A. When syncing is done, everything shows “up to date” except the remote device A (viewed on U) which says “syncing 0%”. The same thing occurs if I add another trusted device C to sync with U. It will also say “Up to Date” on the C side and “syncing 0%” on the U side.
After restarting the same occurs but with different devices. One device will always be “Up to Date” while the other two show “syncing”.
I’m happy to provide logs and/or file an issue on github if you with. Thanks for your help!
