Recursive Use of ReadDirectoryChanges ? window syncthing (github.com/syncthing/notify)
only test: use syncthing notify package (GitHub - syncthing/notify: File system event notification library on steroids.)
window operating system, when I create Y:\1006100210002\Info.… , when I create Y:\1006100210002\Info\A directory, it will trigger time, and continue to create Y:\1006100210002\Info\A\B, then the B directory event will not will trigger.
Other test data:
Sounds like a bug
Because when I was using syncthing, I found that there were files created on the window and no events were monitored, so I did a demonstration test on the notify package used by syncthing and found that I really couldn’t get the monitoring events of subdirectories or files.
my test code in github https://github.com/shumintao/notifytest
this problem causes the file to not be uploaded in time,I really want to fix this problem, but I haven’t fixed it for a long time, can you help me solve it? Thank you so much, I’ve had a lot of headaches with this problem.
watcher_readdcw.go (17.6 KB)
brother, are you ignoring me?
We discuss things in the forum. Once consensus has been reached (“looks like a bug” or “feature XY makes sense”) it’s better to open a Github issue.
At the moment I just want to know how to solve this problem, I really don’t know how to solve this problem now.and very anxious
We don’t know either. Someone needs to debug it. The notify library is a fork of a public library, we don’t have much experience with it.
Oh, I feel so sad…
