Recently upgraded to syncthing 2.0.10 on a Kindle jailbroken paperwhite; but constant I/O errors, problem with syncthing setup or flash memory of underlying device?
Host devices are a mac mini, and a macbook pro
error he required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model) 2025-10-08 20:34:10 WRN Failed to sync (path=“nextup/All Amazon Shareholder Letters.sdr/metadata.pdf.lua” error=“syncing: no connected device has the required version of this file” folder.label=Ebooks folder.id=dfdmz-idylr folder.type 2025-10-08 20:54:23 INF Connection closed (device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CMPE5DCOJVGR7HTTAM5UPF4K error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)
Seeing quite a bit of ‘no such file or directory’ and the kindle has been trying to sync for the last 30 minutes and only 25 of nearly 1G has been synced:
Here’s more of the log:
2025-10-08 20:57:14 WRN Failed to sync (path="daily/[Martin_Meadows]_365_Days_With_Self-Discipline__36(z-lib.org).sdr/metadata.epub.sync-conflict-20200317-134717-PT52E4R.lua" error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:14 WRN Failed to sync (path="fiction/11_22_63 - Stephen King.sdr/metadata.mobi.lua" error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path="nextup/101 Essays That Will Change The Way You Think by Brianna Wiest (z-lib.org).sdr/metadata.epub.lua.old" error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path=.MoonReader/Statements.pdf_1.png error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path=.MoonReader/the-lessons-we-are-learning-from-zoom-chen-en-39470.epub_1.png error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path="downloads/backup-koreader-2020-12-29/koreader/fonts/LiterataBoldItalic-qd10.ttf filenameUTF-8LiterataBoldItalic-qd10.ttf" error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path=downloads/backup-koreader-2020-12-29/koreader/fonts/literata2/static/Literata-Light-opsz=36.ttf error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path=.MoonReader/mastering-adulthood-fielding-en-34000.epub_1.png error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path="politics/White Fragility Why It’s So Hard for White People to Talk About Racism by Robin DiAngelo, Michael Eric Dyson (z-lib.org).sdr/metadata.epub.sync-conflict-20220803-130520-JV6A7TT.lua" error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path=downloads/fonts/static/Literata_18pt/Literata_18pt-BoldItalic.ttf error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path="john muir trail/The John Muir Trail (Alan Castle) (Z-Library).epub" error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path="nextup/[Adams_Douglas]_The_Hitchhiker's_Guide_to_the_Gala(b-ok.cc).epub" error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path=downloads/backup-koreader-2020-12-29/koreader/fonts/literata2/static/Literata-SemiBoldItalic-opsz=60.ttf error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 WRN Failed to sync (path="daily/[Martin_Meadows]_365_Days_With_Self-Discipline__36(z-lib.org).sdr/metadata.epub.sync-conflict-20210224-153907-WDTITXW.lua" error="syncing: no connected device has the required version of this file" folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:15 INF Folder failed to sync, will be retried (wait=1m45s folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)
2025-10-08 20:57:19 INF Established secure connection (device=KVM2DGH connection.local=192.168.0.111:22000 connection.remote=192.168.0.152:22000 connection.type=quic-server connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=20 connection.id=63CMQ2TQ301VM8EMEGHJRRBLIE log.pkg=connections)
2025-10-08 20:57:19 INF New device connection (device=KVM2DGH address=192.168.0.152:22000 remote.name=MacBookArooni remote.client=syncthing remote.version=v2.0.10 log.pkg=model)
2025-10-08 20:57:22 INF Lost device connection (kind=primary device=KVM2DGH connection=192.168.0.111:22000-192.168.0.152:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CMQ2TQ301VM8EMEGHJRRBLIE error="handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory" remaining=0 log.pkg=model)
2025-10-08 20:57:22 INF Connection closed (device=KVM2DGH connection=192.168.0.111:22000-192.168.0.152:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CMQ2TQ301VM8EMEGHJRRBLIE error="handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory" log.pkg=model)
2025-10-08 20:57:23 INF Established secure connection (device=KVM2DGH connection.local=0.0.0.0:22000 connection.remote=192.168.0.152:22000 connection.type=quic-client connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=20 connection.id=63CMQ3A91GOJGS5BFRJVPESF2Q log.pkg=connections)
2025-10-08 20:57:23 INF New device connection (device=KVM2DGH address=192.168.0.152:22000 remote.name=MacBookArooni remote.client=syncthing remote.version=v2.0.10 log.pkg=model)
2025-10-08 20:57:26 INF Lost device connection (kind=primary device=KVM2DGH connection=0.0.0.0:22000-192.168.0.152:22000/quic-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CMQ3A91GOJGS5BFRJVPESF2Q error="handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory" remaining=0 log.pkg=model)
2025-10-08 20:57:26 INF Connection closed (device=KVM2DGH connection=0.0.0.0:22000-192.168.0.152:22000/quic-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CMQ3A91GOJGS5BFRJVPESF2Q error="handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory" log.pkg=model)
finally dmesg:
[ 7051.244334] <<-GTP-INFO->> Guitar reset
[ 7051.464557] <<-GTP-INFO->> GTP wakeup sleep.
[ 7051.464687] <<-GTP-INFO->> Esd started
[ 7342.842111] kernel:pmic:clamp_soc:28,vbat:3611000
[ 7460.896027] usb_gadget_chg_det_sync
[ 7460.897152] max14656_detect_worker:320 0x63, 0x00, 0x13, 0x1f
[ 7460.897166] max14656_detect_worker:323 chg_type=0b0011
[ 7460.897175] pmic_current_event_handler:1182 max dcin current:900mA, ifst:1000mA
[ 7460.916053] charger connected:335 bitflags: 0x04
[ 7461.203418] kernel:pmic:clamp_soc:27,vbat:3612000
[ 7642.835609] kernel:pmic:clamp_soc:28,vbat:3957000
[ 7762.848937] kernel:pmic:clamp_soc:29,vbat:3966000
[ 7767.868969] EXT3-fs error (device mmcblk1p9): ext3_lookup: deleted inode referenced: 45121
[ 7768.515347] EXT3-fs error (device mmcblk1p9): ext3_lookup: deleted inode referenced: 45121
[ 7822.833259] kernel:pmic:clamp_soc:30,vbat:3967000
[ 7882.831799] kernel:pmic:clamp_soc:31,vbat:3971000
[ 7942.832538] kernel:pmic:clamp_soc:32,vbat:3974000
[ 8002.841580] kernel:pmic:clamp_soc:33,vbat:3977000
[ 8029.127902] gtp: gtp_touch_write_ioctl::command=lock:
[ 8029.127917] <<-GTP-INFO->> System suspend.
[ 8029.127924] <<-GTP-INFO->> Esd cancelled
[ 8029.146026] <<-GTP-INFO->> GTP enter sleep!
[ 8029.146039] <<-GTP-INFO->> GTP power off.
[ 8031.020782] kernel:pmic:clamp_soc:34,vbat:3977000
[ 8212.487815] kernel:pmic:clamp_soc:35,vbat:4020000
[ 8332.641290] kernel:pmic:clamp_soc:36,vbat:3997000
[ 8453.198299] kernel:pmic:clamp_soc:37,vbat:4030000
[ 8513.205799] kernel:pmic:clamp_soc:38,vbat:4036000
[ 8573.213298] kernel:pmic:clamp_soc:39,vbat:4027000
[ 8669.340299] EXT3-fs error (device mmcblk1p9): ext3_lookup: deleted inode referenced: 45121
[ 8670.136316] EXT3-fs error (device mmcblk1p9): ext3_lookup: deleted inode referenced: 45121
[ 8694.488293] kernel:pmic:clamp_soc:40,vbat:4052000
[ 8754.492003] kernel:pmic:clamp_soc:41,vbat:4061000
[ 8814.491003] kernel:pmic:clamp_soc:42,vbat:4041000
[ 8874.490809] kernel:pmic:clamp_soc:43,vbat:4071000
[ 8934.491501] kernel:pmic:clamp_soc:44,vbat:4051000
[ 8994.493989] kernel:pmic:clamp_soc:45,vbat:4066000
[ 9114.511165] kernel:pmic:clamp_soc:46,vbat:4070000
[ 9174.511717] kernel:pmic:clamp_soc:47,vbat:4075000
[ 9234.519584] kernel:pmic:clamp_soc:48,vbat:4078000
[ 9255.323177] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 9255.345341] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 9255.345367] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from e8:eb:20
[ 9255.347111] CFG80211-ERROR) wl_cfg80211_reg_notifier : reg_notifier for intiator:0 not supported : set default
[ 9255.347125] CFG80211-ERROR) wl_cfg80211_reg_notifier : Set country code 00 from User
[ 9255.348781] brcm_wlan_get_country_code: WFO sku: cc='00'
[ 9255.366207] WLDEV-ERROR) wldev_set_country : wldev_set_country: set country for 00 as XZ rev 47
[ 9255.373639] cfg80211: World regulatory domain updated:
[ 9255.373646] cfg80211:  DFS Master region: unset
[ 9255.373651] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9255.373662] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9255.373672] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9255.373680] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9255.373689] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9255.373698] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9255.373705] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9255.373713] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9255.373720] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 9256.146616] Connecting with e8:eb:20 ssid "A********I" len (10) channel=8
[ 9256.168183] wl_bss_connect_done succeeded with e8:eb:20
[ 9256.194700] wl_bss_connect_done succeeded with e8:eb:20
[ 9294.539621] kernel:pmic:clamp_soc:49,vbat:4084000
[ 9354.543694] kernel:pmic:clamp_soc:50,vbat:4115000
[ 9475.684890] kernel:pmic:clamp_soc:51,vbat:4140000
[ 9535.738841] kernel:pmic:clamp_soc:52,vbat:4149000
[ 9567.878637] EXT3-fs error (device mmcblk1p9): ext3_lookup: deleted inode referenced: 45121
[ 9568.621757] EXT3-fs error (device mmcblk1p9): ext3_lookup: deleted inode referenced: 45121
[ 9595.851337] kernel:pmic:clamp_soc:53,vbat:4130000
[ 9655.875689] kernel:pmic:clamp_soc:54,vbat:4135000
[ 9715.921534] kernel:pmic:clamp_soc:55,vbat:4143000
[ 9835.920858] kernel:pmic:clamp_soc:56,vbat:4156000
[ 9895.924025] kernel:pmic:clamp_soc:57,vbat:4163000
[ 9955.931326] kernel:pmic:clamp_soc:58,vbat:4170000
[10015.957252] kernel:pmic:clamp_soc:59,vbat:4178000
[10135.963634] kernel:pmic:clamp_soc:60,vbat:4190000
[10195.971538] kernel:pmic:clamp_soc:61,vbat:4197000
[10256.315879] kernel:pmic:clamp_soc:62,vbat:4231000
[10316.873406] kernel:pmic:clamp_soc:63,vbat:4236000
[10436.881555] kernel:pmic:clamp_soc:64,vbat:4226000
[10468.811371] EXT3-fs error (device mmcblk1p9): ext3_lookup: deleted inode referenced: 45121
[10496.881396] kernel:pmic:clamp_soc:65,vbat:4234000
[10556.881453] kernel:pmic:clamp_soc:66,vbat:4243000
[10616.881820] kernel:pmic:clamp_soc:67,vbat:4251000
[10736.886404] kernel:pmic:clamp_soc:68,vbat:4266000
[10796.891828] kernel:pmic:clamp_soc:69,vbat:4274000
[10856.892974] kernel:pmic:clamp_soc:70,vbat:4281000
[10917.222292] kernel:pmic:clamp_soc:71,vbat:4293000
[11037.232663] kernel:pmic:clamp_soc:72,vbat:4303000
[11097.244820] kernel:pmic:clamp_soc:73,vbat:4311000
[11157.261959] kernel:pmic:clamp_soc:74,vbat:4319000
[11217.260797] kernel:pmic:clamp_soc:75,vbat:4328000
[root@kindle root]#
Looks like a hardware thing :confused:
Well I unmounted that partition and ran e2fsk on it and fixed a bunch of errors . now there are no longer ext3 errors.
still running into stuttering on the initial sync. the setup is on the kindle paperwhite i put a blank folder and am trying to get my desktop computers to move the ebooks to the kindle. all devices are running 2.0.10 release. let me know if you’d like more logs:
Dongle Host Driver, version 1.363.110.23 (r)Compiled from[ 69.892982] Register interface [wlan0] MAC: cc:d5:98
[ 72.276899] Connecting with e8:eb:20 ssid “A********I” len (10) channel=10
[ 72.317153] wl_bss_connect_done succeeded with e8:eb:20[ 72.326373] wl_bss_connect_done succeeded with e8:eb:20[ 73.174751] bd71827-rtc bd71827-rtc: bd71827_rtc_set_time, rtc time set to 2025-10-09 15:36:24[ 73.176256] bd71827-rtc bd71827-rtc: bd71827_rtc_alarm_irq_enable: disable rtc alarm[ 88.410203] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.[ 115.943426] EXT3-fs (mmcblk1p8): using internal journal[root@kindle root]#[root@kindle root]# Gdmdmesg | egrep -i ‘EXT3-fs (mmcblk1p9)|ext3_lookup|error|corrupt’ | tail -n 20^C[root@kindle root]# dmesg | egrep -i ‘EXT3-fs (mmcblk1p9)|ext3_lookup|error|corrupt’ | tail -n 20[ 9.251157] EXT3-fs (mmcblk1p9): using internal journal[ 9.252390] EXT3-fs (mmcblk1p9): recovery complete[ 9.252399] EXT3-fs (mmcblk1p9): mounted filesystem with ordered data mode[root@kindle root]# cd /mnt/us[root@kindle us]# tail -f syncthing.log2025-10-09 08:41:46 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“spiritual/WiRE_ A One-Year, Twice-A-Week Devotional for Busy Men - Justin Camp.sdr/metadata.epub.sync-conflict-20210218-021919-WDTITXW.lua” file.modified=“2021-01-14 07:05:16 -0700 MST” file.permissions=0660 file.size=6825 file.blocksize=131072 blocks.local=0 blocks.download=1 log.pkg=model)2025-10-09 08:41:47 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=downloads/backup-koreader-2020-12-29/koreader/fonts/literata2/static/Literata-LightItalic-opsz=9.ttf file.modified=“2020-12-29 14:08:56 -0700 MST” file.permissions=0660 file.size=232352 file.blocksize=131072 blocks.local=0 blocks.download=2 log.pkg=model)2025-10-09 08:41:47 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“nextup/Factotum by Charles Bukowski (z-lib.org).sdr/metadata.epub.lua” file.modified=“2021-08-26 14:27:34 -0700 MST” file.permissions=0660 file.size=37200 file.blocksize=131072 blocks.local=0 blocks.download=1 log.pkg=model)2025-10-09 08:41:48 INF Lost device connection (kind=primary device=YPP7AJP connection=192.168.0.111:37029-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRJR2OELMJ67J3T5O64OMD4K error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:41:48 INF Connection closed (device=YPP7AJP connection=192.168.0.111:37029-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRJR2OELMJ67J3T5O64OMD4K error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:41:48 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=downloads/fonts/static/Literata_24pt/Literata_24pt-ExtraBoldItalic.ttf file.modified=“2018-12-05 23:00:00 -0700 MST” file.permissions=0660 file.size=232636 file.blocksize=131072 blocks.local=0 blocks.download=2 log.pkg=model)2025-10-09 08:41:48 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=downloads/backup-koreader-2020-12-29/koreader/fonts/literata2/static/Literata-Italic-opsz=7.ttf file.modified=“2020-12-29 14:08:56 -0700 MST” file.permissions=0660 file.size=232328 file.blocksize=131072 blocks.local=0 blocks.download=2 log.pkg=model)2025-10-09 08:41:48 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“syncthing/spiritual/._Young, Sarah” file.modified=“2025-10-08 14:13:38 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:41:48 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=downloads/backup-koreader-2020-12-29/koreader/fonts/literata2/static/._Literata-SemiBold-opsz=72.ttf file.modified=“2025-10-08 14:11:00 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:41:48 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“.MoonReader/.Tony Robbins 50 Inspirational Life Lesson - Tony Rob.epub_1.png” file.modified=“2025-10-08 14:10:10 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:41:54 INF Detected NAT type (uri=quic://0.0.0.0:22000 type=“Port restricted NAT” log.pkg=connections)2025-10-09 08:41:54 INF Resolved external address (uri=quic://0.0.0.0:22000 address=quic://99.13.195.174:22000 via:3478=stun.voipstunt.com log.pkg=connections)2025-10-09 08:41:55 INF Established secure connection (device=KVM2DGH connection.local=192.168.0.111:57974 connection.remote=172.93.167.234:22067 connection.type=relay-client connection.lan=false connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=50 connection.id=63CRJSBT9PS0466CT94HE9D35K log.pkg=connections)2025-10-09 08:41:55 INF New device connection (device=KVM2DGH address=172.93.167.234:22067 remote.name=MacBookArooni remote.client=syncthing remote.version=v2.0.10 log.pkg=model)2025-10-09 08:41:55 INF Established secure connection (device=YPP7AJP connection.local=192.168.0.111:22000 connection.remote=192.168.0.100:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=10 connection.id=63CRJSCOEQAE8IMASVOLG24S7E log.pkg=connections)2025-10-09 08:41:55 INF New device connection (device=YPP7AJP address=192.168.0.100:22000 remote.name=MacMiniArooni.local remote.client=syncthing remote.version=v2.0.9 log.pkg=model)2025-10-09 08:41:59 INF Lost device connection (kind=primary device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRJSCOEQAE8IMASVOLG24S7E error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:41:59 INF Connection closed (device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRJSCOEQAE8IMASVOLG24S7E error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:41:59 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“daily/365 Days Of Inspiration (569)/365 Days Of Inspiration - Napoleon Hill.sdr/metadata.epub.lua.sync-conflict-20250930-070352-FAWTMWC.old” file.modified=“2025-09-27 20:02:07.693063733 -0700 MST” file.permissions=0644 file.size=104659 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:41:59 INF Lost device connection (kind=primary device=KVM2DGH connection=192.168.0.111:57974-172.93.167.234:22067/relay-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P50-63CRJSBT9PS0466CT94HE9D35K error=“handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:41:59 INF Connection closed (device=KVM2DGH connection=192.168.0.111:57974-172.93.167.234:22067/relay-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P50-63CRJSBT9PS0466CT94HE9D35K error=“handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:41:59 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=daily/morning-success-ritual-v40.sdr/._metadata.epub.sync-conflict-20220224-164133-H2MGACM.lua file.modified=“2025-10-08 14:10:50 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:41:59 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“.MoonReader/._No More Mr Nice Guy - Robert A. Glover.mobi_1.png” file.modified=“2025-10-08 14:10:12 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:42:03 WRN Failed to acquire open port (mapping=0.0.0.0:22000/TCP id=NAT-PMP@192.168.0.1 error=“getting new lease on NAT-PMP@192.168.0.1 (external port 54356 → internal port 22000): read udp 192.168.0.111:60501->192.168.0.1:5351: recvfrom: connection refused” log.pkg=nat)2025-10-09 08:42:05 INF Established secure connection (device=KVM2DGH connection.local=192.168.0.111:45893 connection.remote=66.59.196.57:22067 connection.type=relay-server connection.lan=false connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=50 connection.id=63CRJTGG3L3T0AMQKQ71I60MHM log.pkg=connections)2025-10-09 08:42:05 INF New device connection (device=KVM2DGH address=66.59.196.57:22067 remote.name=MacBookArooni remote.client=syncthing remote.version=v2.0.10 log.pkg=model)2025-10-09 08:42:06 INF Established secure connection (device=KVM2DGH connection.local=192.168.0.111:57985 connection.remote=172.93.167.234:22067 connection.type=relay-client connection.lan=false connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=50 connection.id=63CRJTM63UI10OT5E44J0N45Q4 log.pkg=connections)2025-10-09 08:42:06 INF Additional device connection (device=KVM2DGH address=172.93.167.234:22067 count=1 log.pkg=model)2025-10-09 08:42:06 INF Lost device connection (kind=primary device=KVM2DGH connection=192.168.0.111:45893-66.59.196.57:22067/relay-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P50-63CRJTGG3L3T0AMQKQ71I60MHM error=“handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=1 log.pkg=model)2025-10-09 08:42:07 INF Established secure connection (device=YPP7AJP connection.local=192.168.0.111:22000 connection.remote=192.168.0.100:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=10 connection.id=63CRJTNG8O01G9TQ9MVIUQJL88 log.pkg=connections)2025-10-09 08:42:07 INF New device connection (device=YPP7AJP address=192.168.0.100:22000 remote.name=MacMiniArooni.local remote.client=syncthing remote.version=v2.0.9 log.pkg=model)2025-10-09 08:42:11 INF Lost device connection (kind=primary device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRJTNG8O01G9TQ9MVIUQJL88 error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:42:11 INF Connection closed (device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRJTNG8O01G9TQ9MVIUQJL88 error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:42:11 INF Lost device connection (kind=primary device=KVM2DGH connection=192.168.0.111:57985-172.93.167.234:22067/relay-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P50-63CRJTM63UI10OT5E44J0N45Q4 error=“handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:42:11 INF Connection closed (device=KVM2DGH connection=192.168.0.111:57985-172.93.167.234:22067/relay-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P50-63CRJTM63UI10OT5E44J0N45Q4 error=“handling index for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:42:19 WRN Failed to acquire open port (mapping=0.0.0.0:22000/UDP id=NAT-PMP@192.168.0.1 error=“getting new lease on NAT-PMP@192.168.0.1 (external port 54356 → internal port 22000): read udp 192.168.0.111:37787->192.168.0.1:5351: recvfrom: connection refused” log.pkg=nat)
2025-10-09 08:44:17 INF Folder failed to sync, will be retried (wait=2m20s folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive log.pkg=model)2025-10-09 08:44:18 INF Lost device connection (kind=primary device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRKCCRA9BUE6EVK0FD70LLBE error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:44:18 INF Connection closed (device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRKCCRA9BUE6EVK0FD70LLBE error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:44:25 INF Established secure connection (device=YPP7AJP connection.local=192.168.0.111:22000 connection.remote=192.168.0.100:22000 connection.type=quic-server connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=20 connection.id=63CRKDQP9IQ7IKBL5T9QDG0N4G log.pkg=connections)2025-10-09 08:44:25 INF New device connection (device=YPP7AJP address=192.168.0.100:22000 remote.name=MacMiniArooni.local remote.client=syncthing remote.version=v2.0.9 log.pkg=model)2025-10-09 08:44:28 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“syncthing/nextup/._Harrison Bergeron.sdr” file.modified=“2025-10-08 14:13:36 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:44:28 INF Lost device connection (kind=primary device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CRKDQP9IQ7IKBL5T9QDG0N4G error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:44:28 INF Connection closed (device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CRKDQP9IQ7IKBL5T9QDG0N4G error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:44:28 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=downloads/backup-koreader-2020-12-29/koreader/fonts/literata2/static/._Literata-ExtraLightItalic-opsz=36.ttf file.modified=“2025-10-08 14:11:06 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:44:33 INF Established secure connection (device=YPP7AJP connection.local=0.0.0.0:22000 connection.remote=192.168.0.100:22000 connection.type=quic-client connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=20 connection.id=63CRKEP15I8P43TCM683LGUV7Q log.pkg=connections)2025-10-09 08:44:33 INF New device connection (device=YPP7AJP address=192.168.0.100:22000 remote.name=MacMiniArooni.local remote.client=syncthing remote.version=v2.0.9 log.pkg=model)2025-10-09 08:44:36 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“john muir trail/Day section hikes John Muir Trail (Dodge, KathleenSummers, Jordan) (Z-Library).sdr/._metadata.epub.lua.sync-conflict-20250922-124912-47BQZ4D.old” file.modified=“2025-10-08 14:12:24 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:44:36 INF Lost device connection (kind=primary device=YPP7AJP connection=0.0.0.0:22000-192.168.0.100:22000/quic-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CRKEP15I8P43TCM683LGUV7Q error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:44:36 INF Connection closed (device=YPP7AJP connection=0.0.0.0:22000-192.168.0.100:22000/quic-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CRKEP15I8P43TCM683LGUV7Q error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:44:36 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“.MoonReader/._jared-taylor-extremism-in-america - Unknown.pdf_1.png” file.modified=“2025-10-08 14:10:16 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:44:41 INF Established secure connection (device=YPP7AJP connection.local=192.168.0.111:22000 connection.remote=192.168.0.100:22000 connection.type=tcp-server connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=10 connection.id=63CRKFNGGFHB6BG292GTIRI0MA log.pkg=connections)2025-10-09 08:44:41 INF New device connection (device=YPP7AJP address=192.168.0.100:22000 remote.name=MacMiniArooni.local remote.client=syncthing remote.version=v2.0.9 log.pkg=model)2025-10-09 08:44:45 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“syncthing/getabstract+summaries/._the-rules-of-contagion-kucharski-en-38362 (1).sdr” file.modified=“2025-10-08 14:13:38 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:44:45 INF Lost device connection (kind=primary device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRKFNGGFHB6BG292GTIRI0MA error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:44:45 INF Connection closed (device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-63CRKFNGGFHB6BG292GTIRI0MA error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:44:45 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“nextup/Hollywood by Bukowski Charles (z-lib.org).sdr/._metadata.epub.lua” file.modified=“2025-10-08 14:12:40 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:44:46 INF Established secure connection (device=YPP7AJP connection.local=192.168.0.111:22000 connection.remote=192.168.0.100:22000 connection.type=quic-server connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=20 connection.id=63CRKG7QKOJ8230ELG5V0R31Q8 log.pkg=connections)2025-10-09 08:44:46 INF New device connection (device=YPP7AJP address=192.168.0.100:22000 remote.name=MacMiniArooni.local remote.client=syncthing remote.version=v2.0.9 log.pkg=model)2025-10-09 08:44:47 INF Lost device connection (kind=primary device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CRKG7QKOJ8230ELG5V0R31Q8 error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:44:47 INF Connection closed (device=YPP7AJP connection=192.168.0.111:22000-192.168.0.100:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CRKG7QKOJ8230ELG5V0R31Q8 error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:44:53 INF Established secure connection (device=YPP7AJP connection.local=0.0.0.0:22000 connection.remote=192.168.0.100:22000 connection.type=quic-client connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=20 connection.id=63CRKH3JBA45E00Q2MDTGPVEP4 log.pkg=connections)2025-10-09 08:44:53 INF New device connection (device=YPP7AJP address=192.168.0.100:22000 remote.name=MacMiniArooni.local remote.client=syncthing remote.version=v2.0.9 log.pkg=model)2025-10-09 08:44:55 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name=“daily/[Martin_Meadows]_365_Days_With_Self-Discipline__36(z-lib.org).sdr/.metadata.epub.sync-conflict-20200225-092447-PT52E4R.lua" file.modified=“2025-10-08 14:10:36 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)2025-10-09 08:44:55 INF Lost device connection (kind=primary device=YPP7AJP connection=0.0.0.0:22000-192.168.0.100:22000/quic-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CRKH3JBA45E00Q2MDTGPVEP4 error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” remaining=0 log.pkg=model)2025-10-09 08:44:55 INF Connection closed (device=YPP7AJP connection=0.0.0.0:22000-192.168.0.100:22000/quic-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-63CRKH3JBA45E00Q2MDTGPVEP4 error=“handling index-update for dfdmz-idylr: update (insert file): disk I/O error: no such file or directory” log.pkg=model)2025-10-09 08:44:55 INF Synced file (folder.label=Ebooks folder.id=dfdmz-idylr folder.type=sendreceive file.name="syncthing/self help/.[Greene_Robert]_The_48_laws_of_power(z-lib.org).sdr” file.modified=“2025-10-08 14:13:32 -0700 MST” file.permissions=0777 file.size=4096 file.blocksize=131072 blocks.local=1 blocks.download=0 log.pkg=model)
I think that your device is toast…
there are no messages on dmesg anymore about file system errors after running fsck. the synchronization is eventually happening but slowly; synced about 700MB with 30MB remaining. so working? i guess?
the remaining out of sync items are “
There are quite a few “disk I/O” errors within those ~3 minutes of log entries. The internal flash memory is very likely mapping out the bad blocks, but without a full wipe, there’s no way to know how bad the problem really is. It wouldn’t be surprising if filesystem corruption pops up again soon.
I don’t think the device is toast. I’m getting the exact same errors on a PW10 with syncing 2.0 and greater. Syncthing 1.30 and prior works as expected with no errors.
A snippet from the logs posted earlier:
That looks like a database error. Given that Syncthing 1.x and 2.x use wildly different database engines, it’s not surprising that the same errors don’t appear when running 1.x.
SQLite in Syncthing 2.x supports ACID while LevelDB does not (LevelDB’s primary focus is performance). SQLite has layers upon layers of sanity checks to reduce the risk of database corruption due to power loss, filesystem errors, etc. It also means SQLite is more sensitive to hardware issues than LevelDB.
When a HDD goes bad, it’s often very noticeable and seldom drawn out. But USB, SSD, eMMC and other flash media often die slowly, block by block.
I ran a dmesg just as arooni did, no errors. This is from a fresh boot:
[root@kindle root]# dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.1.15-lab126 (builder@eink-builds) (gcc version 4.9.1 (GCC) ) #1 SMP PREEMPT Fri Mar 14 08:45:24 UTC 2025 [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: Lab126 i.MX6SLL Board [ 0.000000] dt: falcon bios 0x9ffd0000(0x30000) [ 0.000000] dt: storage bios 0x9ffc0000(0x10000) [ 0.000000] dt: falcon work 0x0 [ 0.000000] log_goal_location: 0x9be00000 [ 0.000000] Printk log placed at 0x9be00000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] Falcon BIOS found. [ 0.000000] On node 0 totalpages: 130304 [ 0.000000] free_area_init_node: node 0, pgdat 80c07d40, node_mem_map 9f97f000 [ 0.000000] DMA zone: 1152 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 130304 pages, LIFO batch:31 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] PERCPU: Embedded 12 pages/cpu@9ff94000@9ff94000 s17216 r8192 d23744 u49152 [ 0.000000] pcpu-alloc: s17216 r8192 d23744 u49152 alloc=124096 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129152 [ 0.000000] Kernel command line: console=ttymxc0,115200 consoleblank=0 uart_at_4m root=/dev/mmcblk1p8 rootwait quiet secure_cpu=1 androidboot.secure_cpu=1 androidboot.prod=1 androidboot.unlocked_kernel=false [ 0.000000] Prink buffer had been relocated to physical address: 0x9be00000 [ 0.000000] log_buf_len: 262144 bytes [ 0.000000] early log buf free: 260128(99%) [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 495552K/521216K available (8344K kernel code, 560K rwdata, 3124K rodata, 360K init, 579K bss, 25664K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xa0800000 - 0xff000000 (1512 MB) lowmem : 0x80000000 - 0xa0000000 ( 512 MB) modules : 0x7f000000 - 0x80000000 ( 16 MB) .text : 0x80008000 - 0x80b3b4a4 (11470 kB) .init : 0x80b3c000 - 0x80b96000 ( 360 kB) .data : 0x80b96000 - 0x80c22078 ( 561 kB) .bss : 0x80c25000 - 0x80cb5e8c ( 580 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] L2C-310 erratum 769419 enabled [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] L2C-310: enabling full line of zeros but not enabled in Cortex-A9 [ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76430001 [ 0.000000] mxc_clocksource_init 3000000 [ 0.000000] Switching to timer-based delay loop, resolution 333ns [ 0.000006] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns [ 0.000023] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns [ 0.001033] Console: colour dummy device 80x30 [ 0.001049] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000) [ 0.001063] pid_max: default: 32768 minimum: 301 [ 0.001168] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001179] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001732] Initializing cgroup subsys memory [ 0.001783] CPU: Testing write buffer coherency: ok [ 0.002004] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002078] Setting up static identity map for 0x80008280 - 0x800082d8 [ 0.060198] Brought up 1 CPUs [ 0.060213] SMP: Total of 1 processors activated (6.00 BogoMIPS). [ 0.060223] CPU: All CPU(s) started in SVC mode. [ 0.060689] devtmpfs: initialized [ 0.067353] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.069456] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.069799] pinctrl core: initialized pinctrl subsystem [ 0.070843] NET: Registered protocol family 16 [ 0.071687] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.100284] cpuidle: using governor ladder [ 0.130313] cpuidle: using governor menu [ 0.146011] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.146024] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.148610] imx6sll-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver [ 0.193732] SCSI subsystem initialized [ 0.193959] libata version 3.00 loaded. [ 0.194260] usbcore: registered new interface driver usbfs [ 0.194333] usbcore: registered new interface driver hub [ 0.194420] usbcore: registered new device driver usb [ 0.195887] bd71827 0-004b: Device ID=0x31 [ 0.197512] bd71827 0-004b: BD71827_REG_INT_STAT_00=0x54 [ 0.198329] bd71827 0-004b: BD71827_REG_INT_STAT_01=0x00 [ 0.199141] bd71827 0-004b: BD71827_REG_INT_STAT_02=0x00 [ 0.199945] bd71827 0-004b: BD71827_REG_INT_STAT_03=0x40 [ 0.200789] bd71827 0-004b: BD71827_REG_INT_STAT_04=0x00 [ 0.201600] bd71827 0-004b: BD71827_REG_INT_STAT_05=0xB2 [ 0.202406] bd71827 0-004b: BD71827_REG_INT_STAT_06=0x00 [ 0.203212] bd71827 0-004b: BD71827_REG_INT_STAT_07=0x00 [ 0.204015] bd71827 0-004b: BD71827_REG_INT_STAT_08=0x02 [ 0.204817] bd71827 0-004b: BD71827_REG_INT_STAT_09=0x01 [ 0.205619] bd71827 0-004b: BD71827_REG_INT_STAT_10=0x30 [ 0.206420] bd71827 0-004b: BD71827_REG_INT_STAT_11=0x00 [ 0.207222] bd71827 0-004b: BD71827_REG_INT_STAT_12=0x00 [ 0.208024] bd71827 0-004b: BD71827_REG_INT_STAT_13=0x00 [ 0.208037] bd71827 0-004b: RESET_REASON = 0x1 [ 0.208051] bd71827 0-004b: Reboot Reason: SOFTWARE_RESTART Software Shutdown [ 0.208451] bd71827 0-004b: gpio_intr = 120 [ 0.208462] bd71827 0-004b: chip_irq=148 [ 0.214898] bd71827-pmic bd71827-pmic: regulator register name ‘buck1’ [ 0.216663] bd71827-pmic bd71827-pmic: regulator register name ‘buck2’ [ 0.218375] bd71827-pmic bd71827-pmic: regulator register name ‘buck3’ [ 0.219220] bd71827-pmic bd71827-pmic: regulator register name ‘buck4’ [ 0.220084] bd71827-pmic bd71827-pmic: regulator register name ‘buck5’ [ 0.220954] bd71827-pmic bd71827-pmic: regulator register name ‘ldo1’ [ 0.221803] bd71827-pmic bd71827-pmic: regulator register name ‘ldo2’ [ 0.222684] bd71827-pmic bd71827-pmic: regulator register name ‘ldo3’ [ 0.223326] bd71827-pmic bd71827-pmic: regulator register name ‘ldo4’ [ 0.224193] bd71827-pmic bd71827-pmic: regulator register name ‘ldo5’ [ 0.225054] bd71827-pmic bd71827-pmic: regulator register name ‘ldo6’ [ 0.225641] bd71827-pmic bd71827-pmic: regulator register name ‘ldosnvs’ [ 0.226081] bd71827-pmic bd71827-pmic: Buck0: DVS Run-Idle-Susp[1100000 - 900000 - 900000]. [ 0.227259] bd71827-pmic bd71827-pmic: Buck1: DVS Run-Idle-Susp[1100000 - 900000 - 900000]. [ 0.229915] i2c i2c-0: IMX I2C adapter registered [ 0.229937] i2c i2c-0: can’t use DMA [ 0.230675] i2c i2c-1: IMX I2C adapter registered [ 0.230698] i2c i2c-1: can’t use DMA [ 0.231226] i2c i2c-2: IMX I2C adapter registered [ 0.231245] i2c i2c-2: can’t use DMA [ 0.231377] Linux video capture interface: v2.00 [ 0.231460] pps_core: LinuxPPS API ver. 1 registered [ 0.231469] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it [ 0.231499] PTP clock support registered [ 0.232527] MIPI CSI2 driver module loaded [ 0.232711] Advanced Linux Sound Architecture Driver Initialized. [ 0.233564] Bluetooth: Core ver 2.20 [ 0.233620] NET: Registered protocol family 31 [ 0.233628] Bluetooth: HCI device and connection manager initialized [ 0.233646] Bluetooth: HCI socket layer initialized [ 0.233656] Bluetooth: L2CAP socket layer initialized [ 0.233696] Bluetooth: SCO socket layer initialized [ 0.234562] Switched to clocksource mxc_timer1 [ 0.236621] cfg80211: World regulatory domain updated: [ 0.236633] cfg80211: DFS Master region: unset [ 0.236642] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [ 0.236653] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [ 0.236664] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 0.236674] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) [ 0.236686] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 0.236696] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) [ 0.236705] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) [ 0.236714] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [ 0.236722] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) [ 0.243688] idme_init: hwid = 12 [ 0.243713] idme_init: alscal2 = 0 [ 0.243729] idme_init: alscal1 = 0 [ 0.243789] idme_init: vcom = -2870000 [ 0.243855] idme_init: main 5 [ 0.243862] idme_init: can’t read bootmode err=-22 [ 0.243948] idme_init: read serial successfully [ 0.243964] idme_init: read board_id successfully [ 0.244229] NET: Registered protocol family 2 [ 0.244861] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.244912] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.244982] TCP: Hash tables configured (established 4096 bind 4096) [ 0.245044] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.245069] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.245233] NET: Registered protocol family 1 [ 0.245522] RPC: Registered named UNIX socket transport module. [ 0.245534] RPC: Registered udp transport module. [ 0.245540] RPC: Registered tcp transport module. [ 0.245548] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.245760] Trying to unpack rootfs image as initramfs… [ 0.268776] Freeing initrd memory: 6428K (9e6a5000 - 9ecec000) [ 0.271097] Bus freq driver module loaded [ 0.272285] qbblk(storage): Enabled per clock [ 0.272305] qbblk(storage): Enabled ipg clock [ 0.272322] qbblk(storage): Enabled ahb clock [ 0.272346] qbblk(storage): Enabled epit clock [ 0.272355] qbblk(storage): Set pinctrl [ 0.273304] futex hash table entries: 256 (order: 2, 16384 bytes) [ 0.280409] VFS: Disk quotas dquot_6.6.0 [ 0.280599] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.282045] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.282816] NFS: Registering the id_resolver key type [ 0.282850] Key type id_resolver registered [ 0.282858] Key type id_legacy registered [ 0.282942] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 0.283652] fuse init (API version 7.23) [ 0.288071] io scheduler noop registered [ 0.288091] io scheduler deadline registered [ 0.288277] io scheduler cfq registered (default) [ 0.290452] MIPI DSI driver module loaded [ 0.290612] MIPI DSI driver module loaded [ 0.292559] imx-sdma 20ec000.sdma: no event needs to be remapped [ 0.292702] imx-sdma 20ec000.sdma: loaded firmware 3.3 [ 0.295236] imx-sdma 20ec000.sdma: initialized [ 0.296122] reg-virt-consumer regulator-virtuals:virt-buck1: attached: buck1 [ 0.296508] reg-virt-consumer regulator-virtuals:virt-buck2: attached: buck2 [ 0.296882] reg-virt-consumer regulator-virtuals:virt-buck3: attached: buck3 [ 0.297241] reg-virt-consumer regulator-virtuals:virt-buck4: attached: buck4 [ 0.297595] reg-virt-consumer regulator-virtuals:virt-buck5: attached: buck5 [ 0.297956] reg-virt-consumer regulator-virtuals:virt-ldo1: attached: ldo1 [ 0.298325] reg-virt-consumer regulator-virtuals:virt-ldo2: attached: ldo2 [ 0.298440] reg-virt-consumer regulator-virtuals:virt-ldo3: attached: ldo3 [ 0.298561] reg-virt-consumer regulator-virtuals:virt-ldo4: attached: ldo4 [ 0.298666] reg-virt-consumer regulator-virtuals:virt-ldo5: attached: ldo5 [ 0.299023] reg-virt-consumer regulator-virtuals:virt-ldo6: attached: ldo6 [ 0.299399] reg-virt-consumer regulator-virtuals:virt-ldosnvs: attached: ldosnvs [ 0.300348] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 250000) is a IMX [ 0.323248] console [ttymxc0] enabled [ 0.323890] 2034000.serial: ttymxc2 at MMIO 0x2034000 (irq = 19, base_baud = 250000) is a IMX [ 0.358714] imx-rng 21b4000.rngb: iMX RNG Registered. [ 0.358908] [drm] Initialized drm 1.1.0 20060810 [ 0.359403] [drm] Initialized vivante 1.0.0 20120216 on minor 0 [ 0.369334] brd: module loaded [ 0.374209] loop: module loaded [ 0.374865] zram: Created 1 device(s) [ 0.375086] bt_pwrctrl_init called.. [ 0.375313] bt_reset pin obtained is 51 [ 0.375330] bt_dev_wake pin obtained is 116 [ 0.375342] bt_host_wake pin obtained is 93 [ 0.375364] IRQ# for BT HOST WAKE: 119 [ 0.379424] bt_pwrctrl_probe probe successful [ 0.379550] frontlight /dev entries driver [ 0.383016] misc frontlight: new frontlight device (backlight:bl) registered. [ 0.387549] CAN device driver interface [ 0.389165] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver [ 0.389204] ehci-mxc: Freescale On-Chip EHCI Host driver [ 0.389381] usbcore: registered new interface driver usb-storage [ 0.390361] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator [ 0.391574] mousedev: PS/2 mouse device common for all mice [ 0.392352] input: 20cc000.snvs:snvs-powerkey as /devices/soc0/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0 [ 0.393841] bd71827-rtc bd71827-rtc: Enabling rtc-bd71827. [ 0.398966] bd71827-rtc bd71827-rtc: rtc core: registered bd71827-rtc as rtc0 [ 0.399432] bd71827-rtc probe time: 125:9:18-10:35:33: [ 0.400136] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1 [ 0.400297] i2c /dev entries driver [ 0.401408] IR NEC protocol handler initialized [ 0.401427] IR RC5(x/sz) protocol handler initialized [ 0.401438] IR RC6 protocol handler initialized [ 0.401449] IR JVC protocol handler initialized [ 0.401461] IR Sony protocol handler initialized [ 0.401474] IR SANYO protocol handler initialized [ 0.401489] IR Sharp protocol handler initialized [ 0.401502] IR MCE Keyboard/mouse protocol handler initialized [ 0.401514] IR XMP protocol handler initialized [ 0.402755] max14656 2-0035: detected revision 15 [ 0.404133] bd71827_set_battery_parameters found battType:4, battID:0x52 [ 0.407452] bd71827_safe_charging_control on_off:0 [ 0.417417] input: bd71827-power as /devices/soc0/soc/2100000.aips-bus/21a0000.i2c/i2c-0/0-004b/bd71827-power/input/input1 [ 0.430399] usb_gadget_chg_det_sync [ 0.436820] imx2-wdt 20bc000.wdog: use WDOG_B to reboot. [ 0.437427] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0) [ 0.437900] softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0) [ 0.437945] Bluetooth: HCI UART driver ver 2.3 [ 0.437956] Bluetooth: HCI UART protocol H4 registered [ 0.437985] Bluetooth: HCI UART protocol BCSP registered [ 0.437994] Bluetooth: HCI UART protocol ATH3K registered [ 0.438357] usbcore: registered new interface driver bcm203x [ 0.438521] usbcore: registered new interface driver btusb [ 0.438787] usbcore: registered new interface driver ath3k [ 0.439532] sdhci: Secure Digital Host Controller Interface driver [ 0.439663] sdhci: Copyright(c) Pierre Ossman [ 0.439700] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.442338] /soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified [ 0.442532] sdhci-esdhc-imx 2190000.usdhc: assigned as wifi host [ 0.443757] kernel:pmic:clamp_soc:46,vbat:3776000 [ 0.443937] sdhci-esdhc-imx 2190000.usdhc: No vmmc regulator found [ 0.443969] sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found [ 0.484684] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA [ 0.497531] usbcore: registered new interface driver usbhid [ 0.497542] usbhid: USB HID core driver [ 0.584316] get_host_info: Found target host info [ 0.584330] init_falcon_blk: Not Use interrupt [ 0.609901] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p10 [ 0.617950] NET: Registered protocol family 26 [ 0.617980] Netfilter messages via NETLINK v0.30. [ 0.618021] nfnl_acct: registering with nfnetlink. [ 0.618078] nf_conntrack version 0.5.0 (7843 buckets, 31372 max) [ 0.618626] ctnetlink v0.93: registering with nfnetlink. [ 0.618882] nf_tables: (c) 2007-2009 Patrick McHardy kaber@trash.net [ 0.618901] nf_tables_compat: (c) 2012 Pablo Neira Ayuso pablo@netfilter.org [ 0.619490] xt_time: kernel timezone is -0000 [ 0.619522] IPVS: Registered protocols () [ 0.619555] IPVS: Connection hash table configured (size=4096, memory=32Kbytes) [ 0.619661] IPVS: Creating netns size=872 id=0 [ 0.619709] IPVS: ipvs loaded. [ 0.620152] ip_tables: (C) 2000-2006 Netfilter Core Team [ 0.620279] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully [ 0.620328] arp_tables: (C) 2002 David S. Miller [ 0.620385] NET: Registered protocol family 17 [ 0.620405] can: controller area network core (rev 20120528 abi 9) [ 0.620479] NET: Registered protocol family 29 [ 0.620497] can: raw protocol (rev 20120528) [ 0.620510] can: broadcast manager protocol (rev 20120528 t) [ 0.620525] can: netlink gateway (rev 20130117) max_hops=1 [ 0.620808] Bluetooth: RFCOMM TTY layer initialized [ 0.620828] Bluetooth: RFCOMM socket layer initialized [ 0.620857] Bluetooth: RFCOMM ver 1.11 [ 0.620879] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 0.620887] Bluetooth: BNEP filters: protocol multicast [ 0.620900] Bluetooth: BNEP socket layer initialized [ 0.620913] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 0.620925] Bluetooth: HIDP socket layer initialized [ 0.620996] 8021q: 802.1Q VLAN Support v1.8 [ 0.621060] Key type dns_resolver registered [ 0.622542] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19) [ 0.629634] cpufreq: __cpufreq_add_dev: CPU0: Running at unlisted freq: 792000 KHz [ 0.633164] cpufreq: __cpufreq_add_dev: CPU0: Unlisted initial frequency changed to: 996000 KHz [ 0.653615] state=0 [ 1.096943] bd71827-rtc bd71827-rtc: setting system clock to 2025-10-18 10:35:34 UTC (1760783734) [ 1.102244] ldo5: disabling [ 1.102936] ldo4: disabling [ 1.103373] eMMC_VCCQ: disabling [ 1.103382] SD1_SPWR: disabling [ 1.103536] ALSA device list: [ 1.103543] No soundcards found. [ 1.104062] Freeing unused kernel memory: 360K (80b3c000 - 80b96000) [ 1.116978] INFO:mount /dev/mmcblk1p2 to /mnt/wfm OK [ 1.118285] INFO:find_file:165 Found 320_R249_AI2902_ED060KC4C3_TC.wrf.gz [ 1.118337] INFO:find 1 waveform files [ 1.118410] INFO:Loading: /lib/modules/mxc_epdc_v2_fb.ko waveform=320_R249_AI2902_ED060KC4C3_TC.wrf.gz [ 1.121781] Panel VCOM settings: -2870000 hwid: 12 [ 1.154832] imx_epdc_v2_fb 20f4000.epdc: use reserved working buffer @ 0x9b000000 [ 1.177126] imx_epdc_v2_fb 20f4000.epdc: ok to request xon pins 109 [ 1.183958] requesting waveform imx/epdc/epdc_ED060KC4.fw [ 1.193001] imx_epdc_v2_fb 20f4000.epdc: mxc_epdc_fb_fw_handler: enter [ 1.193085] imx_epdc_v2_fb 20f4000.epdc: read_mnt_wfm_v2: waveform at /mnt/wfm/waveform_to_use/320_R249_AI2902_ED060KC4C3_TC.wrf.gz [ 1.193100] imx_epdc_v2_fb 20f4000.epdc: read_mnt_wfm_v2: open file (/mnt/wfm/waveform_to_use/320_R249_AI2902_ED060KC4C3_TC.wrf.gz) ok size=95609 [ 1.198529] imx_epdc_v2_fb 20f4000.epdc: read_mnt_wfm_v2: read file OK [ 1.214452] imx_epdc_v2_fb 20f4000.epdc: allocate 3261253 byte @ a2c29000 for waveform [ 1.220353] imx_epdc_v2_fb 20f4000.epdc: long 70 xswi 31c326 [ 1.220378] imx_epdc_v2_fb 20f4000.epdc: copy (31c326 - 31bee8) byte @ offset 31bee8 to acd buffer [ 1.220400] imx_epdc_v2_fb 20f4000.epdc: copy (31bee8 - 31b628) byte @ offset 31b628 to vcd buffer [ 1.220411] imx_epdc_v2_fb 20f4000.epdc: Retrieved voltage control information (0x8c0) [ 1.220420] imx_epdc_v2_fb 20f4000.epdc: epd_vc_data mode=9 temp=13 size = 16 waveform_mc=10 waveform_trc=14 [ 1.220433] imx_epdc_v2_fb 20f4000.epdc: – VC Data version 0x0004 : vddh_ext = 0x0000, vee_ext = 0x0028, xon_len = 0x00fb, xon_delay = 0x0008, [ 1.220444] imx_epdc_v2_fb 20f4000.epdc: vddh = 0x07d0, vee = 0x0640, vcom_offset = 0x0000, v_l = 0x0108, vpdd_len = 0x001e cs = 0x0073– [ 1.220453] imx_epdc_v2_fb 20f4000.epdc: epd_vc_data mode=8 temp=13 size = 16 waveform_mc=10 waveform_trc=14 [ 1.220464] imx_epdc_v2_fb 20f4000.epdc: – VC Data version 0x0004 : vddh_ext = 0x0000, vee_ext = 0x0028, xon_len = 0x00fb, xon_delay = 0x0008, [ 1.220476] imx_epdc_v2_fb 20f4000.epdc: vddh = 0x07d0, vee = 0x0640, vcom_offset = 0x0000, v_l = 0x0108, vpdd_len = 0x001e cs = 0x0073– [ 2.424965] max14656_detect_worker:320 0x00, 0x00, 0x00, 0x1f [ 2.424978] max14656_detect_worker:323 chg_type=0b0000 [ 2.424988] pmic_current_event_handler:1194 max dcin current:450mA, ifst:550mA [ 2.445222] no charger connected:358 bitflags: 0x00 [ 2.445232] turn off VBUS [ 2.884598] imx_epdc_v2_fb 20f4000.epdc: Update region is outside bounds of framebuffer.Aborting update. [ 2.894347] INFO:Loaded module /lib/modules/mxc_epdc_v2_fb.ko waveform=320_R249_AI2902_ED060KC4C3_TC.wrf.gz (152552 bytes) [ 2.914435] INFO:eink initialized… (1575424 bytes) [ 2.914738] INFO:is_production=1, is_unlocked=0, is_secure_cpu=1 [ 2.915469] INFO:Battery ID is valid [ 2.919061] INFO:Battery percentage = 46 [ 2.922701] INFO:alloc_read_gpt_entries: count = 128 * 128 = 16384 [ 2.954624] INFO:Setup loop device /dev/loop0 for /dev/mmcblk1p10 + 8192 [ 2.955362] EXT4-fs (loop0): VFS: Can’t find ext4 filesystem [ 2.989424] INFO:Mounted /mnt-us (/dev/loop0) fs_type=vfat [ 2.989549] INFO:Checking for updates… (auto-pilot mode) [ 2.989716] INFO:No update.bin found; no update needed. [ 3.074641] INFO:no updates found. [ 3.733162] screen update triggered SOC update skipped [ 4.271997] EXT3-fs (mmcblk1p8): mounted filesystem with ordered data mode [ 4.272157] kjournald starting. Commit interval 5 seconds [ 5.185439] random: head urandom read with 85 bits of entropy available [ 5.355556] udevd (202): /proc/202/oom_adj is deprecated, please use /proc/202/oom_score_adj instead. [ 5.583733] bd_soc_update_work_callback: clamp_soc=46 [ 7.438855] random: nonblocking pool is initialized [ 8.580896] falcon: module license ‘newBSD’ taints kernel. [ 8.580911] Disabling lock debugging due to kernel taint [ 8.585460] BIOS require 5103616 bytes buffer [ 8.585626] Allocate new buffer area [ 8.733561] EXT3-fs (mmcblk1p3): mounted filesystem with ordered data mode [ 8.736563] kjournald starting. Commit interval 5 seconds [ 9.108502] EXT3-fs (mmcblk1p8): using internal journal [ 9.126277] EXT3-fs (mmcblk1p9): using internal journal [ 9.126295] EXT3-fs (mmcblk1p9): mounted filesystem with ordered data mode [ 9.127488] kjournald starting. Commit interval 5 seconds [ 11.135512] <<-GTP-INFO->> GTP driver installing… [ 11.141889] <<-GTP-INFO->> GTP Driver Version: V2.4.0.1<2016/10/26> [ 11.141904] <<-GTP-INFO->> GTP I2C Address: 0x14 [ 11.142018] <<-GTP-INFO->> GTP power on. [ 11.143875] <<-GTP-INFO->> Guitar reset [ 11.355560] <<-GTP-INFO->> IC Version: 967_1077 [ 11.365621] <<-GTP-INFO->> X_MAX: 1072, Y_MAX: 1448, TRIGGER: 0x01 [ 11.384655] <<-GTP-INFO->> create proc entry touch success [ 11.384952] <<-GTP-INFO->> create proc entry gt9xx_config success [ 11.384963] <<-GTP-INFO->> Esd started [ 11.384971] <<-GTP-INFO->> Ready to run update thread. [ 11.390981] input: goodix-ts as /devices/virtual/input/input2 [ 11.392236] <<-GTP-INFO->> GTP works in interrupt mode. [ 11.392254] <<-GTP-INFO->> Applied memory size:2562. [ 11.392261] <<-GTP-INFO->> I2C function: without pre and end cmd! [ 11.392276] <<-GTP-INFO->> Create proc entry success! [ 11.411341] <<-GTP-INFO->> FILE CFG Ver:99 [ 11.411355] <<-GTP-INFO->> IC CFG Ver:99 [ 11.411360] <<-GTP-INFO->> File CFG Ver <= Ic CFG Ver, update config aborted! [ 11.421311] <<-GTP-INFO->> FILE HARDWARE INFO:00016000 [ 11.421324] <<-GTP-INFO->> FILE PID:967 [ 11.421329] <<-GTP-INFO->> FILE VID:1077 [ 11.421336] <<-GTP-INFO->> IC HARDWARE INFO:00900600 [ 11.421342] <<-GTP-INFO->> IC PID:967 [ 11.421346] <<-GTP-INFO->> IC VID:1077 [ 11.421351] <<-GTP-INFO->> Firmware length:90112(88K) [ 11.421356] <<-GTP-INFO->> Don’t meet the third condition. [ 11.421360] <<-GTP-INFO->> File VID <= Ic VID, update aborted! [ 22.946996] Mass Storage Function, version: 2009/09/11 [ 22.947014] LUN: removable file: (no medium) [ 22.947102] LUN: removable file: (no medium) [ 22.947111] Number of LUNs=1 [ 22.947121] Number of LUNs=1 [ 22.951784] g_mass_storage gadget: Internal Storage, version: 2009/09/11 [ 22.951799] g_mass_storage gadget: g_mass_storage ready [ 24.183138] zram0: detected capacity change from 0 to 134217728 [ 24.231059] Adding 131068k swap on /dev/zram0. Priority:-1 extents:1 across:131068k SS [ 42.748238] dhd_module_init in [ 42.748269] dhd_module_init fw_image_unaligned=92d80000 fw_image=92d80000 [ 42.748302] brcm_wlan_power: setting gpio #[47] on [ 42.906080] found wifi platform device bcmdhd_wlan [ 42.907523] dhd_module_init out [ 43.004816] mmc0: new high speed SDIO card at address 0001 [ 43.007202] alloc static buf at 9cbc0000! [ 43.011473] DHD: dongle ram size is set to 524288(orig 524288) at 0x0 [ 43.011631] wifi_platform_get_mac_addr [ 43.011654] brcm_wlan_get_country_code: WFO sku: cc=‘’ [ 43.038273] dhd_deferred_work_init: work queue initialized [ 43.039522] dhdsdio_download_code_file@4294941599@4294941599: read fw to 92d80000 [ 43.137721] dhdsdio_download_code_file@4294941609@4294941609: finished download fw_image_size=369119 [ 43.139434] dhdsdio_download_nvram: len=1166 read [ 43.139447] dhdsdio_download_nvram: len=1166 saved [ 43.200598] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us) [ 43.200826] bcmsdh_oob_intr_register OOB irq=121 flags=4 [ 43.201598] wifi_platform_get_mac_addr [ 43.204716] Firmware up: op_mode=0x0005, MAC=7c:fe:15 [ 43.205143] dhd_preinit_ioctls:7847 wl ampdu_hostreorder failed -23 [ 43.256027] Firmware version = wl0: Mar 29 2021 18:23:27 version 7.45.102.16 (r728411 CY) FWID 01-361e1702 [ 43.259296] Dongle Host Driver, version 1.363.110.23 (r) Compiled from [ 43.259859] Register interface [wlan0] MAC: 7c:fe:15
[ 45.212637] bd_soc_update_work_callback: clamp_soc=46 [ 46.139466] Connecting with b0:a0:e5 ssid “P****2” len (6) channel=6
[ 46.167449] wl_bss_connect_done succeeded with b0:a0:e5 [ 46.259654] wl_bss_connect_done succeeded with b0:a0:e5 [ 48.692037] bd71827-rtc bd71827-rtc: bd71827_rtc_set_time, rtc time set to 2025-10-18 10:36:21 [ 48.692569] bd71827-rtc bd71827-rtc: bd71827_rtc_alarm_irq_enable: disable rtc alarm [ 49.440619] screen update triggered SOC update skipped [ 49.552009] screen update triggered SOC update skipped [ 49.562825] kernel:pmic:clamp_soc:45,vbat:3734000 [ 49.562839] bd_soc_update_work_callback: clamp_soc=45 [ 50.843589] screen update triggered SOC update skipped [ 51.768029] screen update triggered SOC update skipped [ 52.410612] bd_soc_update_work_callback: clamp_soc=45 [ 53.544854] screen update triggered SOC update skipped [ 54.450900] screen update triggered SOC update skipped [ 55.170060] bd_soc_update_work_callback: clamp_soc=45 [ 56.295627] screen update triggered SOC update skipped [ 57.187121] screen update triggered SOC update skipped [ 57.901310] bd_soc_update_work_callback: clamp_soc=45 [ 59.122521] screen update triggered SOC update skipped [ 59.894471] screen update triggered SOC update skipped [ 60.599943] bd_soc_update_work_callback: clamp_soc=45
[root@kindle root]# mount | grep /mnt/us fsp on /mnt/us type fuse.fsp (rw,nosuid,nodev,noatime,user_id=0,group_id=0,allow_other) fsp on /var/tmp/chroot/mnt/us type fuse.fsp (rw,nosuid,nodev,noatime,user_id=0,group_id=0,allow_other)
Maybe this is more of fuse slowing down sqlite? The low-spec hardware is listed in dmesg as well. We are talking about two different devices with the same I/O problem. I could see that the kindle isn’t up to par for syncthing 2.0, and I certainly wouldn’t ask for 2.x to support these devices. If there is some other way to confirm a bad block device I’m willing to chase this out. In any case, hopefully if someone else comes along this will keep them from wasting time on v 2.x.
Just for reference. I’m running into the same problem on a jailbroken kindle scribe.
Hi all, i’m experiencing the same issue on 4 devices, 2 Kindle Oasis and 2 (new) Kindle Scribe. Issues starting when updating from Syncthing 1.x to 2.x.
The initial setup seems to work, but soon after that syncing stops and the below errors are logged. I also tried completely removing Syncthing and doing a new setup entirely, which did not help either.
Please advise how to troubleshoot :slight_smile:
2026-03-21 11:11:39 INF syncthing v2.0.15 "Hafnium Hornet" (go1.26.0 linux-arm) builder@github.syncthing.net 2026-02-11 10:41:38 UTC (log.pkg=main)
2026-03-21 11:11:40 INF Calculated our device ID (device=**************************** log.pkg=syncthing)
2026-03-21 11:11:40 INF Overall rate limit in use (send="is unlimited" recv="is unlimited" log.pkg=connections)
2026-03-24 09:51:13 INF Established secure connection (device=XXXXXXX connection.local=192.168.1.27:22000 connection.remote=192.168.1.19:22000 connection.type=quic-server connection.lan=true connection.crypto=TLS1.3-TLS_CHACHA20_POLY1305_SHA256 connection.prio=20 connection.id=64VNBIOP9A91A6BF1KG4HCSJLU log.pkg=connections)
2026-03-24 09:51:13 INF New device connection (device=XXXXXXX address=192.168.1.19:22000 remote.name=xxxxxxxx remote.client=syncthing remote.version=v2.0.15 log.pkg=model)
2026-03-24 09:51:14 INF Lost device connection (kind=primary device=XXXXXXX connection=192.168.1.27:22000-192.168.1.19:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-64VNBIOP9A91A6BF1KG4HCSJLU error="handling index-update for YYYYYYYY: update (insert file): disk I/O error: no such file or directory" remaining=0 log.pkg=model)
2026-03-24 09:51:14 INF Connection closed (device=XXXXXXX connection=192.168.1.27:22000-192.168.1.19:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P20-64VNBIOP9A91A6BF1KG4HCSJLU error="handling index-update for YYYYYYYY: update (insert file): disk I/O error: no such file or directory" log.pkg=model)
I switched from gutenye’s syncthing-kindle ( GitHub - gutenye/syncthing-kindle: Setup Syncthing on Kindle Touch · GitHub ), a KUAL extension, to jasonchoimtt’s koreader-syncthing ( GitHub - jasonchoimtt/koreader-syncthing: Syncthing plugin for KOReader · GitHub ), a KOReader plugin with a start-syncthing wrapper script. The koreader setup automates the firewall part, and I didn’t need to edit the wrapper script to alternate between syncthing 1.30 and 2.x for testing. Obviously the config.xml file needed to be modified or updated though.
Syncthing 1.30.0 runs fine. The same koreader syncthing plugin running Syncthing 2.1.0 worked better / a little quicker than with the kindle KUAL setup, but with no firewall manual configuration/setup. Syncthing connected to peers, scanned, exchanged index IDs, then failed on every incoming index update with:
handling index-update for <folder>: update (insert file): disk I/O error: no such file or directory
as well as:
vacuumandoptimize (VACUUM;): disk I/O error: no such file or directory
The connection then drops, the peer reconnects, the same insert failed again, over and over. Swapping the 1.30 and 2.x binaries back and forth, with no other changes, flipped the problem on and off. Nothing new with any of this.
Cause
The database lived on /mnt/us, which on this device is a FUSE mount (fuse.fsp) over the underlying VFAT userstore, mounted with the hard_remove option.
From /etc/fstab:
fsp#/mnt/base-us  /mnt/us  fuse  allow_other,umask=0,uid=0,gid=0,rw,max_write=65536,max_readahead=65536,noatime,noexec,nosuid,nodev,nonempty,hard_remove  0  0
and # mount :
From looking at the FUSE documentation, with hard_remove set, an unlinked-but-still-open file is deleted immediately rather than renamed to a hidden .fuse_hiddenXXX file, and subsequent read/write/fsync/ftruncate/etc. on that descriptor return ENOENT.
I think this is messing up SQLite: hence “disk I/O error: no such file or directory.”
I was thinking the problem is in how the differences in how thetwo database systems work with the filesystem being the cause of the problem.
Fix
I moved the Syncthing database off /mnt/us onto an ext3 filesystem, and /var/local (/dev/mmcblk1p9) is ext3 with enough free space. Syncthing 2.x lets you set the config and data directories separately, so I kept config and keys on /mnt/us/koreader/settings/syncthing and put only the database on /var/local/syncthing.
Create a new data (database) directory (I used koreader’s ssh server for this):
mkdir -p “/var/local/syncthing”
Edit (or see the attached file) /mnt/us/koreader/plugins/syncthing.koplugin/start-syncthing add a separate data directory:
point --data at it in three locations.
Before (lines 4-7):
config_dir=settings/syncthing
syncthing=plugins/syncthing.koplugin/syncthing
pid_file=/tmp/syncthing_koreader.pid
After:
data_dir=/var/local/syncthing
Then lines 30-35, lines 40-43, and lines 47-53:
change --data=“$config_dir” to --data=“$data_dir” in the generate, –device-id, and serve blocks.
After this, I did a fresh rescan onto /var/local/syncthing to create index-v2 and completed my folders’ initial scans and synced cleanly – no “disk I/O error” lines at all.
So far so good, I’ve been trying figure this out off and on for awhile. Hopefully this helps shine a light on things.
start-syncthing (1.4 KB)
Nice troubleshooting. Truly we live in the future, when we need this amount of command line faffing on what is effectively a book. :wink:
Thank you for figuring out the fix and documenting it here. Couldn’t figure out why the library wouldn’t finish syncing and ran into the error messages in the logs. Back to normal after the fix mentioned here.
