Great! Thanks for the fast answer.
An upgrade check that fails now and then could be all sorts of reasons here. Most likely an unstable uplink. Now I know where to look.
Thanks again!
Hm. Keeps happening on all v0.14.46 Windows clients. Not on any of the Linux or Mac clients, whatever their version. And I found it to happen on v0.14.45 Windows as well.
Interestingly, it says in the GUI where it deals with “Automatic upgrades” that those are “Unavailable/Disabled by administrator or maintainer”. I have no idea how I could have done that, or how to revert it.
I usually don’t go into the Advanced Config, but looking at the settings there I can see the option “Auto Upgrade Interval (hours)” to be “12” on all Windows machines. Seems to be the default. Is there another setting controlling the autoupgrade?
Btw: Has nothing to do with anything installed on Windows (have tested on freshly installed Win 10 Enterprise x64 v1709 VM (as well as v1709+current updates as of today). The VM is stand-alone, has internet access of course, but no config like Group Policies or anything that would interfere.
I’d like to switch one client to get the release candidates and see if it updates as it should when the next RC is made available. Too bad the GUI setting is not available…
Try to manually load the upgrade url (it’s in the config, by default https://upgrades.syncthing.net/meta.json). Enable tracing of upgrade and look at the log (you can do this in the GUI).
If I open https://upgrades.syncthing.net/meta.json in my browser, I do get a lot of binary blobs in my output from line 690 onwards - to me it looks like the file is corrupted.
That doesn’t happen for me and I can’t figure out how it would happen. Save a copy of that file and put it somewhere, see if we can make sense of what the binary is?
