Hi there, I’m quite confused, because I didn’t really change anything about my setup:
Syncthing via Docker on Unraid, I’ve mounted the full filesystem of the server into the docker (as read/write slave)
I’m getting lots of unsynced Item’s / failed items (a few more unsynced than failed) in multiple folders.
syncing: finishing: opening temp file: open /path/to/folder/.syncthing.FILENAME.ext.tmp: read-only file system
This sync worked before, although I found that in one folder the versions were all corrupt (.xml - not readable anymore) - might be unrelated though…
