Hello,
I have a few questions/suggestions about protocol/DISCOVERY.md
for local discovery, it mentions that it is with a broadcast message, but fails to mention the port, 21025/UDP.
Device ID. The XDR syntax is
string DeviceID<>
, while it seems to me that ST accepts only the SHA-256 of the certificate (see code), so the XDR should bestring DeviceID<32>
and the text should mention that the only allowed length is 32. -
Device ID. Probably the text should mention that the Device ID is the SHA-256 of the certificate, and maybe point to the device ID documentation page.
Device ID again . Call me nitpicker, but the SHA-256 is a binary blob, not a string (there is a presentation transformation as explained at deviceid, but on the wire it is just a binary blob). As such, the XDR type should be
opaque
, notstring
. (Yes I know that they are encoded the same, but the semantics are different). -
Port. The XDR for
struct Address
containsunsigned short Port
, but the typeshort
doesn’t exist in XDR. The text should beunsigned int Port
, and the text should mention that the value should fit in a 16-bit unsigned integer, since that is the size of a UDP port. -
Query. The XDR has a typo, it says
struct Announcement
instead ofstruct Query
Let me know if you want a pull request with the suggested changes.
Cheers, and thanks for ST!
