Hi, I have a master-slave configuration with only two nodes. Last week I had a couple of problems:
- My slave node had a failure so I had to replace the device, but since I saved the “.config/syncthing” folder I could rebuilt it without requesting a join and so on.
- When I restored the device I noticed it was syncing a lot of stuff which was strange since nothing changed on the master so I checked and I found that by my mistake I’ve restarted the master without mounting the disk containing the data.
- Stopping syncthing, mounting the disk, restarting it and doing a scan resulted in the picture below.
So my question is: Since the global state shows more file than the local one, and since I don’t have any clue of what those 2GB could be, is there any way to get a list of changes between local state and global state? I thought that this would be the behavior of clicking on the “Out of Sync Items”, but as you can see this is ~1.50KiB and if I click it shows me a list of folders which are already present on my master device so those 12 folders are present and I’m now wondering where the ~2GB are from, maybe files inside of them? But in this case… which files? I’m now afraid that some files are missing from the mounted disk, but I don’t know which ones.
