Would the increase in the number of copiers be a suitable reaction to the following problem?
Last week our 200+GB synced folder stopped its work and while Network IO was low, the system itself had a high CPU load. This caused a lot of confusion and I spent a day investigating it.
What I suspect: a user moved a directory containing around 20000 small files into another place which caused the block-tracker to be so overwhelmed by requests that it stopped the regular sync while it sorted out the change.
While I recreated the directory from the most intact copy whilst throwing out the problematic folder I would have liked to understand how I could avoid such problems in the future. So: was the amount of copiers the problem and would it be okay to put 4 copiers to work under such circumstances?
I doubt the number of copiers would have much impact. I also doubt the root cause of the issue. We fixed a couple of things in the last releases, mostly around big files, but could still be related. Moving a directory with 20k files in it shouldn’t take that long or overwhelm it, I’d be surprised if it took more than a minute or so. Assuming we’re not talking about a phone or something.
