I was previously using syncthing-bar, but moved over to QSyncthingTray, but the icon stays grey and I can’t access the GUI (either from the menu or in a browser address bar.
I’ve tried using both the 127.x.x.x address and localhost, but neither work. I’ve deleted the old app completely from my laptop and was going to set up the folders again in the settings.
Hopefully someone knows the issue! I’m writing a story for a DJ technology site about how to set up syncing your music library over multiple computers.
Thanks. Resolved it with their help. It was an issue with the settings in the Syncthing server: the web GUI address was misnamed ‘lcalhost’, so I bypassed it using the CLI and changed it properly in the settings.
Probably a bit out of topic, but are you on Syncthing v12 or v11?
I noticed the changes in the REST API last night (leading to an incorrect
number of connections being displayed) and committed some fixes.
Will pull out a new release probably tomorrow, but I’m just curious whether
its worth the effort to maintain downwards compatibility to v11.
