Tom
(Tom Staels)
1
Hi all,
When does ST iterate through a .stversions folder to clean up files with age > Max Age ?
Daily at midnight?
Hourly?
On rescan of shared folder?
None of the above ?
source code seems to imply hourly :
cleanInterval = 3600 // Default: clean once per hour
thx,
Tom
calmh
(Jakob Borg)
2
Correct. It also cleans old versions of the file it is versioning, when it versions a file.
Looking at it now, I can see the hourly cleaning getting expensive once there are a lot of files versioned…
