PSA: discovery and Syncthing in a container: use docker host networking
I just spent a little while chasing my tail, ending up back where I should have started: the doc linked from the docker image doc. As noted therein, discovery won’t work if you use Docker’s standard NAT/port mapping; you’ll need to use host networking. (though why does that doc give the port-mapping version as an example?)
One thing that threw me a little was the discussion in How do I advertise addresses for clients to connect to but the solution therein (adding the host address to the listen address) won’t work: Syncthing inside the standard container/docker networking mode (bridging, NAT) can’t see / doesn’t know of the host’s network interfaces and thus can’t listen on or advertise them.
Guess I need to finally get this done :see_no_evil_monkey:
Using Docker’s host networking mode eliminates the network isolation between the container and the host. Whether this is a concern depends on your specific threat model and use case though.
