bigbear2nd
(Bob Hope)
September 21, 2014, 12:06pm
1
Hi!
When Syncthing is restarted for config changes or some other reason, it is always retransferring the index to all other node.
All nodes know:
When they last saw the all configured nodes.
When was the last file change
If there would be a short handshake:
Did you change any file since you last saw me? Answer yyyy
I have xxxx changes since I last saw you.
If the answer to xxxx and yyyy is “0” then the index should not be retransmitted.
That would speedup the time to sync a lot.
Especially on nodes with large repos and many nodes.
And also makes the frequent restarts less painful.
calmh
(Jakob Borg)
September 21, 2014, 1:02pm
2
Yeah, it’s just not implemented yet. (See the small section about “Max Local Version” here .)
bigbear2nd
(Bob Hope)
September 22, 2014, 2:11am
3
Thank you for your answer, this was excatly what i was looking for.
Should i make an issue for that on GitHub?
In the “Fields” section there is a line:
Exactly one of the T, R or S bits MUST be set.
I didnt see the use or the description of the “S” bit. Is this bit obsolete?
There is now a GitHub issue to this:
opened 10:33PM - 18 Nov 14 UTC
closed 07:46AM - 19 Nov 14 UTC
On mobile devices it's key to keep the traffic as low as possible and Pulse simply isn't very good at this...
frozen-due-to-age
