Syncthing recently stopped running in background on my Samsung Galaxy S24, not sure if there is something I can do to make it work properly again.
My settings are as per the screenshots below.
For testing purposes, please disable the run conditions in the app completely (which will make the app run Syncthing all the time), and if that doesn’t help, then please check https://dontkillmyapp.com/samsung whether it’s not something in the Samsung Android’s settings that blocks it from running.
