Problems With Extended Attributes
Hello:
I’ve just been experimenting with the new (:face_with_raised_eyebrow:) Extended Attributes sync support - and I’ve just come across a few unexpected, yet reproducible, outcomes from doing so.
I’m running a shared folder between two macOS systems, both running Syncthing 1.23.6. Here’s how to reproduce the problems (points of unexpectedness highlighted in bold):
  1. Mac 1: Create Shared Folder in Finder, to use as a Shared Folder root in Syncthing;
  2. Mac 1: Create Folder 1 inside Shared Folder;
  3. Mac 2: Create Shared Folder in Finder, to use as a Shared Folder root in Syncthing;
  4. Mac 1: Share Shared Folder in Syncthing from Mac 1 to Mac 2. Do not enable Sync Extended Attributes;
  5. Mac 2: Accept Shared Folder sync invitation. Do not enable Sync Extended Attributes - note that Folder 1 correctly appears in place;
  6. Mac 1 and Mac 2: Enable Sync Extended Attributes;
  7. Mac 1: Apply a Finder Tag to Folder 1. Prompt a rescan of Shared Folder inside Syncthing;
  8. Mac 2: Note that the Finder Tag does not appear on Folder 1;
  9. Mac 1: Create Folder 2 inside Shared Folder - give it a Finder Tag;
  10. Mac 2: Note that Folder 2, complete with Finder Tag, correctly appears;
  11. Mac 1: Rename Folder 1 to Folder 1a;
  12. Mac 2: Note that Folder 1 AND Folder 1a have now appeared;
  13. Mac 1: Note that Folder 1 AND Folder 1a have appeared here too;
  14. Mac 1: Create Folder 3 inside Shared Folder - give it a Finder Tag;
  15. Mac 2: Note that Folder 3, complete with Finder Tag, correctly appears;
  16. Mac 1: Change the Finder Tag on Folder 3 - do not scan yet;
  17. Mac 2: Change the Finder Tag on Folder 3 differently;
  18. Mac 1 (or Mac 2): Rescan Shared Folder in Syncthing;
  19. Mac 2 (or Mac 1): Note that the Finder Tag on Folder 3 has not changed - and now further changes on this Extended Attribute cannot be synced.
Hope that’s useful in improving the support here - thanks for the otherwise, as always, amazing tool!
I tried to reproduce this by following your steps on my mac, but I can’t. None of the weirdness you describe happens to me.
Hi @calmh - thanks for trying.
It’s definitely reproducible here between the two systems I’m trying on - one running macOS 13.5, one running macOS 12.6.7. Both systems have the shared folder on APFS.
My video isn’t as tidy as yours - but hopefully there’s enough useful info there:
