thegameksk
(kerry kushetsk)
February 11, 2019, 4:54am
1
I followed these instruction: https://github.com/feralhosting/feralfilehosting/tree/master/Feral%20Wiki/Software/Syncthing%20-%20Basic%20Setup .
I installed from the script. When I run the command syncthing syncthing just keeps restarting and then a message comes up saying after 4 restarts syncthing wont try to run. Can anyone help?
calmh
(Jakob Borg)
February 11, 2019, 6:08am
2
Post the full log output.
thegameksk
(kerry kushetsk)
February 11, 2019, 6:31am
3
[monitor] 06:12:15 INFO: Starting syncthing
[GLQV2] 06:12:15 INFO: syncthing v1.0.1 "Erbium Earthworm" (go1.11.5 linux-amd64 ) teamcity@build.syncthing.net 2019-01-18 10:34:18 UTC
[GLQV2] 06:12:15 INFO: My ID: GLQV2Y5-JRLM7JU-3HIOL7G-JUTLKET-3GNBPK3-776EJQL-YW G5URE-RCIVHAH
[GLQV2] 06:12:16 INFO: Single thread SHA256 performance is 272 MB/s using minio/sha256-simd (265 MB/s using crypto/sha256).
[GLQV2] 06:12:17 INFO: Hashing performance is 144.84 MB/s
[GLQV2] 06:12:17 FATAL: Error opening database: resource temporarily unavailable (is another instance of Syncthing running?)
[monitor] 06:12:17 INFO: Syncthing exited: exit status 1
[monitor] 06:12:18 INFO: Starting syncthing
[GLQV2] 06:12:18 INFO: syncthing v1.0.1 "Erbium Earthworm" (go1.11.5 linux-amd64) teamcity@build.syncthing.net 2019-01-18 10:34:18 UTC
[GLQV2] 06:12:18 INFO: My ID: GLQV2Y5-JRLM7JU-3HIOL7G-JUTLKET-3GNBPK3-776EJQL-YWG5URE-RCIVHAH
[GLQV2] 06:12:19 INFO: Single thread SHA256 performance is 277 MB/s using minio/sha256-simd (262 MB/s using crypto/sha256).
[GLQV2] 06:12:19 INFO: Hashing performance is 150.38 MB/s
[GLQV2] 06:12:19 FATAL: Error opening database: resource temporarily unavailable (is another instance of Syncthing running?)
[monitor] 06:12:19 INFO: Syncthing exited: exit status 1
[monitor] 06:12:20 INFO: Starting syncthing
[GLQV2] 06:12:21 INFO: syncthing v1.0.1 "Erbium Earthworm" (go1.11.5 linux-amd64) teamcity@build.syncthing.net 2019-01-18 10:34:18 UTC
[GLQV2] 06:12:21 INFO: My ID: GLQV2Y5-JRLM7JU-3HIOL7G-JUTLKET-3GNBPK3-776EJQL-YWG5URE-RCIVHAH
[GLQV2] 06:12:22 INFO: Single thread SHA256 performance is 288 MB/s using minio/sha256-simd (272 MB/s using crypto/sha256).
[GLQV2] 06:12:22 INFO: Hashing performance is 151.01 MB/s
[GLQV2] 06:12:22 FATAL: Error opening database: resource temporarily unavailable (is another instance of Syncthing running?)
[monitor] 06:12:22 INFO: Syncthing exited: exit status 1
[monitor] 06:12:23 INFO: Starting syncthing
[GLQV2] 06:12:23 INFO: syncthing v1.0.1 "Erbium Earthworm" (go1.11.5 linux-amd64) teamcity@build.syncthing.net 2019-01-18 10:34:18 UTC
[GLQV2] 06:12:23 INFO: My ID: GLQV2Y5-JRLM7JU-3HIOL7G-JUTLKET-3GNBPK3-776EJQL-YWG5URE-RCIVHAH
[GLQV2] 06:12:24 INFO: Single thread SHA256 performance is 318 MB/s using crypto/sha256 (309 MB/s using minio/sha256-simd).
[GLQV2] 06:12:25 INFO: Hashing performance is 157.52 MB/s
[GLQV2] 06:12:25 FATAL: Error opening database: resource temporarily unavailable (is another instance of Syncthing running?)
[monitor] 06:12:25 INFO: Syncthing exited: exit status 1
[monitor] 06:12:26 WARNING: 4 restarts in 10.781632176s; not retrying further
calmh
(Jakob Borg)
4
It’s probably already running.
thegameksk
(kerry kushetsk)
February 11, 2019, 6:34am
5
What is the command to stop/restart? Im not sure if it is bc my config file didnt match what the instructions said it would.
system
(system)
Closed
March 13, 2019, 6:34am
6
