Very often (almost always) my mobile devices cannot connect to other devices. There are 4 constantly running servers in my cluster (3 encrypted and 1 normal). I’ve been trying to find a specific problem for a very long time and came up with the following results:
2022-10-11 00:01:16 Listen (BEP/tcp): connect from 192.168.1.144:10006
2022-10-11 00:02:00 Established secure connection to ZTHGQKB-GOUDEBZ-SGN6ZNL-JL5AW7W-HDQPZ6A-M4XBSBF-SV7QKUG-2VSXAAE at 192.168.1.124:22000-192.168.1.144:10006/tcp.3-server/tcp.3-server TLS_CHACHA20_POLY1305_SHA256
The connection is established in 44 seconds!
This is due to the simultaneous connection with 4 devices and the size of the folders (on a mobile device: 8 folders, 23 directories, 470 files, 6.25 gigabytes). If you leave 1 small folder, then the problem disappears. If you connect not at the same time, but in turn, then the problem disappears.
Apparently, the problem is very high CPU usage. After the connection, intensive work takes place. Even my laptop loads the processor at 100% for 40 seconds when connected to 3 encrypted devices (17 folders, 2315 directories, 51731 files, 533 gigabytes)
Not really an answer, but I’ve got a feeling that this will have something to do with the large number of encrypted folders that you’ve got out there. What are the hardware specs of the devices involved?
Take a CPU profile. But yes, initialising encrypted folders for a new connection involves some key generation which I guess can add up if there are many or the device is slow.
Yeah, time is spent in scrypt, generating folder keys from passwords. I guess lucky for you we’re using insecure low-round scrypt or this would take forever. That said, I’m not sure why this needs to happen for every connection, it seems it could happen on folder startup or thereabout.
