problem with temporary files.
I sync a folder in which temporary files are created again and again for a short time, and disappear again. I rarely scan the directory 3 times a day and that seems to get “syncthing” out of the blueprint. What happens there? what happens if I click on “Overwrite changes”? Can anyone explain to me ?
Could not somehow, in addition to the non-syncronized objects, write a reason why they were not synchronized?
New users can only put one image in a post :))) You should not discriminate new users. As you will not get any new users in this this way.
Use your fantasy to imagine the content of the picture I can not upload due to your restriction.
That’s what you see if you go on “527 Objekte ~15.2 MiB”
You should see the error in the tooltip. But as you have this folder as read only, that files were probably changed on another device and as your device doesn’t except changes from other devices, that files are out of sync.
“override changes” will enforce your file versions on the other devices.
