Dear Syncthing experts, we need your valuable inputs in one of the issue we are facing. Below is description, any help highly appreciated.
Problem Description: We are not able to connect two devices which are in different network (Source device in private corporate network and Destination Device in public internet).
- In Source corporate network we have enabled the firewall rules for all the Relay servers with required ports.
Destination Public Relay Servers IP : 162.255.117.212 195.219.226.6 163.172.85.202 94.16.122.162 78.47.248.86 Port : 443 , 22000/TCP, 21027/UDP, 22067/TCP.
- we have also configured Relay servers in both source and destination
Relay Server: relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY
- Below are masked device IDs for source and destination - This will help in understnading the logs
Source (Internal): QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
Destination(External): yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
Devices showing Disconnected in both sides and doesn’t sync any folders.
Alternative, we have tested below scenarios and it is working well.
Sync between Source(Private Network) and Destination(Private Network) - Working Sync between Source(Public Network) and Destination(Public Network) - Working.
Only in Hybrid networks we have this issue.
- we see consistently same logs being displayed for
Below are the Logs for Source and destination for your interpretations and recommendation.
Source Device Logs
2018-08-01 17:23:05 syncthing v0.14.48 "Dysprosium Dragonfly" (go1.10.2 windows-amd64) teamcity@build.syncthing.net 2018-05-14 06:53:06 UTC
2018-08-01 17:23:05 My ID: QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:23:06 Single thread SHA256 performance is 159 MB/s using minio/sha256-simd (99 MB/s using crypto/sha256).
2018-08-01 17:23:06 Hashing performance is 82.83 MB/s
2018-08-01 17:23:06 Overall send rate is unlimited, receive rate is unlimited
2018-08-01 17:23:06 Rate limits do not apply to LAN connections
2018-08-01 17:23:06 Using discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2018-08-01 17:23:06 Using discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2018-08-01 17:23:06 Using discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2018-08-01 17:23:06 Relay listener (relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY) starting
2018-08-01 17:23:06 ...
2018-08-01 17:23:06 GUI and API listening on 127.0.0.1:8384
2018-08-01 17:23:06 Access the GUI via the following URL: http://127.0.0.1:8384/
2018-08-01 17:23:06 Device QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 is "computerinternal" at [dynamic]
2018-08-01 17:23:07 Joined relay relay://94.16.122.162:443
2018-08-01 17:23:28 Couldn't fetch release information: Get https://upgrades.syncthing.net/meta.json: dial tcp 82.196.13.137:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2018-08-01 17:23:28 Automatic upgrade: no version to select
2018-08-01 17:23:37 Couldn't fetch release information: Get https://upgrades.syncthing.net/meta.json: dial tcp 82.196.13.137:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2018-08-01 17:24:43 Adding folder "D:\\SyncMan" (gvrhg-s54sr)
2018-08-01 17:24:43 No stored folder metadata for "gvrhg-s54sr": recalculating
2018-08-01 17:24:43 Ready to synchronize "D:\\SyncMan" (gvrhg-s54sr) (readwrite)
2018-08-01 17:24:43 Completed initial scan of readwrite folder "D:\\SyncMan" (gvrhg-s54sr)
2018-08-01 17:27:04 Restarted folder "D:\\SyncMan" (gvrhg-s54sr) (readwrite)
2018-08-01 17:27:04 Completed initial scan of readwrite folder "D:\\SyncMan" (gvrhg-s54sr)
2018-08-01 17:27:15 Enabled debug data for "connections"
2018-08-01 17:27:16 Enabled debug data for "discover"
2018-08-01 17:27:19 Enabled debug data for "nat"
2018-08-01 17:27:20 Enabled debug data for "protocol"
2018-08-01 17:27:23 Enabled debug data for "sync"
2018-08-01 17:27:24 Enabled debug data for "upnp"
2018-08-01 17:27:24 Reconnect loop
2018-08-01 17:27:24 negative cache entry for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at global@https://discovery-v4.syncthing.net/v2/ valid until 2018-08-01 17:25:09.9102675 +0530 IST m=+125.275890501 or 2018-08-01 18:24:09.9102675 +0530 IST m=+3665.275890501
2018-08-01 17:27:24 negative cache entry for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at global@https://discovery-v6.syncthing.net/v2/ valid until 2018-08-01 17:25:09.9102675 +0530 IST m=+125.275890501 or 2018-08-01 18:24:09.9102675 +0530 IST m=+3665.275890501
2018-08-01 17:27:29 globalClient.Lookup https://discovery.syncthing.net/v2/?device=yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC Get https://discovery.syncthing.net/v2/?device=yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
2018-08-01 17:27:29 lookup for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at IPv4 local
2018-08-01 17:27:29 addresses: []
2018-08-01 17:27:29 lookup for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at IPv6 local
2018-08-01 17:27:29 lookup results for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:27:29 Reconnect loop for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC []
2018-08-01 17:27:29 sleep until next dial 1m0s
2018-08-01 17:27:36 discover: Received local announcement from [fe80::e0:0:0:0%Local Area Connection* 11]:62601 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:27:36 discover: Received local announcement from 192.168.x.x:62600 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:28:06 discover: Received local announcement from 192.168.x.x:62600 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:28:06 discover: Received local announcement from [fe80::e0:0:0:0%Local Area Connection* 11]:62601 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:28:07 Announcement: {"addresses":["relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY"]}
2018-08-01 17:28:07 announce POST: Post https://discovery-v6.syncthing.net/v2/: dial tcp: lookup discovery-v6.syncthing.net: getaddrinfow: The requested name is valid, but no data of the requested type was found.
2018-08-01 17:28:11 Announcement: {"addresses":["relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY"]}
2018-08-01 17:28:16 announce POST: Post https://discovery-v4.syncthing.net/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
2018-08-01 17:28:29 Reconnect loop
2018-08-01 17:28:29 negative cache entry for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at global@https://discovery-v4.syncthing.net/v2/ valid until 2018-08-01 17:25:09.9102675 +0530 IST m=+125.275890501 or 2018-08-01 18:24:09.9102675 +0530 IST m=+3665.275890501
2018-08-01 17:28:29 negative cache entry for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at global@https://discovery-v6.syncthing.net/v2/ valid until 2018-08-01 17:25:09.9102675 +0530 IST m=+125.275890501 or 2018-08-01 18:24:09.9102675 +0530 IST m=+3665.275890501
2018-08-01 17:28:34 globalClient.Lookup https://discovery.syncthing.net/v2/?device=yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC Get https://discovery.syncthing.net/v2/?device=yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
2018-08-01 17:28:34 lookup for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at IPv4 local
2018-08-01 17:28:34 addresses: []
2018-08-01 17:28:34 lookup for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at IPv6 local
2018-08-01 17:28:34 lookup results for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:28:34 Reconnect loop for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC []
2018-08-01 17:28:34 sleep until next dial 1m0s
2018-08-01 17:28:36 discover: Received local announcement from [fe80::e0:0:0:0%Local Area Connection* 11]:62601 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:28:36 discover: Received local announcement from 192.168.x.x:62600 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:29:06 discover: Received local announcement from 192.168.x.x:62600 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:29:06 discover: Received local announcement from [fe80::e0:0:0:0%Local Area Connection* 11]:62601 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:29:34 Reconnect loop
2018-08-01 17:29:34 negative cache entry for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at global@https://discovery-v4.syncthing.net/v2/ valid until 2018-08-01 17:25:09.9102675 +0530 IST m=+125.275890501 or 2018-08-01 18:24:09.9102675 +0530 IST m=+3665.275890501
2018-08-01 17:29:34 negative cache entry for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at global@https://discovery-v6.syncthing.net/v2/ valid until 2018-08-01 17:25:09.9102675 +0530 IST m=+125.275890501 or 2018-08-01 18:24:09.9102675 +0530 IST m=+3665.275890501
2018-08-01 17:29:36 discover: Received local announcement from 192.168.x.x:62600 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:29:36 discover: Received local announcement from [fe80::e0:0:0:0%Local Area Connection* 11]:62601 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:29:39 globalClient.Lookup https://discovery.syncthing.net/v2/?device=yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC Get https://discovery.syncthing.net/v2/?device=yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
2018-08-01 17:29:39 lookup for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at IPv4 local
2018-08-01 17:29:39 addresses: []
2018-08-01 17:29:39 lookup for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at IPv6 local
2018-08-01 17:29:39 lookup results for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:29:39 Reconnect loop for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC []
2018-08-01 17:29:39 sleep until next dial 1m0s
2018-08-01 17:30:06 discover: Received local announcement from 192.168.x.x:62600 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:30:06 discover: Received local announcement from [fe80::e0:0:0:0%Local Area Connection* 11]:62601 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:30:36 discover: Received local announcement from 192.168.x.x:62600 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:30:36 discover: Received local announcement from [fe80::e0:0:0:0%Local Area Connection* 11]:62601 for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:30:39 Reconnect loop
2018-08-01 17:30:39 negative cache entry for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at global@https://discovery-v4.syncthing.net/v2/ valid until 2018-08-01 17:25:09.9102675 +0530 IST m=+125.275890501 or 2018-08-01 18:24:09.9102675 +0530 IST m=+3665.275890501
2018-08-01 17:30:39 negative cache entry for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at global@https://discovery-v6.syncthing.net/v2/ valid until 2018-08-01 17:25:09.9102675 +0530 IST m=+125.275890501 or 2018-08-01 18:24:09.9102675 +0530 IST m=+3665.275890501
2018-08-01 17:30:45 globalClient.Lookup https://discovery.syncthing.net/v2/?device=yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC Get https://discovery.syncthing.net/v2/?device=yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
2018-08-01 17:30:45 lookup for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at IPv4 local
2018-08-01 17:30:45 addresses: []
2018-08-01 17:30:45 lookup for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC at IPv6 local
2018-08-01 17:30:45 lookup results for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:30:45 Reconnect loop for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC []
2018-08-01 17:30:45 sleep until next dial 1m0s
Destination Device Logs
2018-08-01 17:42:52 syncthing v0.14.49 "Dysprosium Dragonfly" (go1.10.3 windows-amd64) teamcity@build.syncthing.net 2018-07-10 15:40:06 UTC
2018-08-01 17:42:52 My ID: yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:42:53 Single thread SHA256 performance is 297 MB/s using crypto/sha256 (293 MB/s using minio/sha256-simd).
2018-08-01 17:42:54 Hashing performance is 246.58 MB/s
2018-08-01 17:42:54 Ready to synchronize "DefaultInternal" (pxtwe-ocap4) (sendreceive)
2018-08-01 17:42:54 Overall send rate is unlimited, receive rate is unlimited
2018-08-01 17:42:54 Rate limits do not apply to LAN connections
2018-08-01 17:42:54 Using discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2018-08-01 17:42:54 Using discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2018-08-01 17:42:54 Using discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2018-08-01 17:42:54 ...
2018-08-01 17:42:54 Relay listener (relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY) starting
2018-08-01 17:42:54 Device yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC is "LaptopExternal" at [dynamic]
2018-08-01 17:42:54 Device QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 is "InternalVM" at [dynamic]
2018-08-01 17:42:54 Completed initial scan of sendreceive folder "DefaultInternal" (pxtwe-ocap4)
2018-08-01 17:42:54 GUI and API listening on 127.0.0.1:8384
2018-08-01 17:42:54 Access the GUI via the following URL: http://127.0.0.1:8384/
2018-08-01 17:43:04 Could not connect to relay relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY: read tcp 192.168.43.36:54837->94.16.122.162:443: i/o timeout
2018-08-01 17:43:04 Relay listener (relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY) shutting down
2018-08-01 17:43:04 Relay listener (relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY) starting
2018-08-01 17:43:04 c.S.listenerSupervisor: Failed service 'relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY' (1.000000 failures of 2.000000), restarting: true, error: "{relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY relay://94.16.122.162:443/?id=GZ6RB5P-WEQSZ6G-22BT5VP-QGPYDKF-BPFMI6J-4BSOIUF-ICTPSB3-6FMOCQY} returned unexpectedly", stacktrace: [unknown stack trace]
2018-08-01 17:43:06 Joined relay relay://94.16.122.162:443
2018-08-01 17:43:09 Enabled debug data for "connections"
2018-08-01 17:43:11 Reconnect loop
2018-08-01 17:43:11 Reconnect loop for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 []
2018-08-01 17:43:11 initial rampup; sleep 16s and update to 32s
2018-08-01 17:43:11 Enabled debug data for "discover"
2018-08-01 17:43:13 Enabled debug data for "nat"
2018-08-01 17:43:14 Enabled debug data for "protocol"
2018-08-01 17:43:16 Enabled debug data for "sync"
2018-08-01 17:43:18 Enabled debug data for "upnp"
2018-08-01 17:43:24 discover: Received local announcement from [fe80::5445:e9dc:c113:f043%Ethernet]:58905 for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:43:24 discover: Received local announcement from 192.168.43.36:58904 for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:43:27 Reconnect loop
2018-08-01 17:43:27 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery-v4.syncthing.net/v2/ valid until 2018-08-01 17:43:54.298492 +0530 IST m=+61.597419701 or 2018-08-01 18:42:54.298492 +0530 IST m=+3601.597419701
2018-08-01 17:43:27 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery-v6.syncthing.net/v2/ valid until 2018-08-01 17:43:54.298492 +0530 IST m=+61.597419701 or 2018-08-01 18:42:54.298492 +0530 IST m=+3601.597419701
2018-08-01 17:43:27 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery.syncthing.net/v2/ valid until 2018-08-01 17:43:56.4599984 +0530 IST m=+63.758994601 or 2018-08-01 17:52:28.4599984 +0530 IST m=+575.758994601
2018-08-01 17:43:27 lookup for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at IPv4 local
2018-08-01 17:43:27 addresses: []
2018-08-01 17:43:27 lookup for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at IPv6 local
2018-08-01 17:43:27 lookup results for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:43:27 Reconnect loop for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 []
2018-08-01 17:43:27 initial rampup; sleep 32s and update to 1m4s
2018-08-01 17:43:54 discover: Received local announcement from 192.168.43.36:58904 for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:43:54 discover: Received local announcement from [fe80::5445:e9dc:c113:f043%Ethernet]:58905 for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:43:59 Reconnect loop
2018-08-01 17:43:59 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery-v4.syncthing.net/v2/ valid until 2018-08-01 17:43:54.298492 +0530 IST m=+61.597419701 or 2018-08-01 18:42:54.298492 +0530 IST m=+3601.597419701
2018-08-01 17:43:59 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery-v6.syncthing.net/v2/ valid until 2018-08-01 17:43:54.298492 +0530 IST m=+61.597419701 or 2018-08-01 18:42:54.298492 +0530 IST m=+3601.597419701
2018-08-01 17:43:59 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery.syncthing.net/v2/ valid until 2018-08-01 17:43:56.4599984 +0530 IST m=+63.758994601 or 2018-08-01 17:52:28.4599984 +0530 IST m=+575.758994601
2018-08-01 17:43:59 lookup for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at IPv4 local
2018-08-01 17:43:59 addresses: []
2018-08-01 17:43:59 lookup for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at IPv6 local
2018-08-01 17:43:59 lookup results for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:43:59 Reconnect loop for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 []
2018-08-01 17:43:59 sleep until next dial 1m0s
2018-08-01 17:44:24 discover: Received local announcement from [fe80::5445:e9dc:c113:f043%Ethernet]:58905 for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:44:24 discover: Received local announcement from 192.168.43.36:58904 for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:44:54 discover: Received local announcement from 192.168.43.36:58904 for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:44:54 discover: Received local announcement from [fe80::5445:e9dc:c113:f043%Ethernet]:58905 for yyyyyK-INyyyyy-yyyyyRL-yyyyyF-5yyyyy-yyyyy4V-yyyyyT5-TR2JSAC
2018-08-01 17:44:59 Reconnect loop
2018-08-01 17:44:59 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery-v4.syncthing.net/v2/ valid until 2018-08-01 17:43:54.298492 +0530 IST m=+61.597419701 or 2018-08-01 18:42:54.298492 +0530 IST m=+3601.597419701
2018-08-01 17:44:59 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery-v6.syncthing.net/v2/ valid until 2018-08-01 17:43:54.298492 +0530 IST m=+61.597419701 or 2018-08-01 18:42:54.298492 +0530 IST m=+3601.597419701
2018-08-01 17:44:59 negative cache entry for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at global@https://discovery.syncthing.net/v2/ valid until 2018-08-01 17:43:56.4599984 +0530 IST m=+63.758994601 or 2018-08-01 17:52:28.4599984 +0530 IST m=+575.758994601
2018-08-01 17:44:59 lookup for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at IPv4 local
2018-08-01 17:44:59 addresses: []
2018-08-01 17:44:59 lookup for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 at IPv6 local
2018-08-01 17:44:59 lookup results for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3
2018-08-01 17:44:59 Reconnect loop for QWZLDZR-6Yxxxx-xxxxCF-KxxxxX-xxxxBNY-Kxxxx-xxxxZC-xxxxA3 []
2018-08-01 17:44:59 sleep until next dial 1m0s
Appreciate if you can help us what we are missing and next steps.
Thanks alot.
