Prioritize small tasks while transferring
I’ve noticed that if I’m already transferring a large file, small tasks get postponed until it finishes. Most annoying being deleting files.
I would like large transfers (or data transfers in general) to take a back seat and dynamically prioritize deleting (or moving) files. Even prioritizing small files before large ones would be nice to have happen on the fly, pausing a large file’s transfer in order to transfer newly added smaller files, assuming the large file isn’t almost done already.
Would this be a feature request, or can I already achieve this somehow?
You can choose to transfer files in size order or random order. I don’t know what happens if a large file is underway and additional small files are found to be transferred.
Docs to the rescue!
https://docs.syncthing.net/users/config.html#config-option-folder.order
Note that the scanned files are sent in batches and the sorting is applied only to the already discovered files. This means the sync might start with a 1 GB file even if there is 1 KB file available on the source device until the 1 KB becomes known to the pulling device.
Yes, and it’s already on GitHub.
At the moment, you can only do it manually, e.g. by pausing and unpausing the related folder.
I’m also not sure prioritizing deletes is a good idea as deleted files might actually be renames if the scanning is still ongoing on the remote side.
Although I have had a situation where syncing stopped because the disk was at the 1% limit because 1TB of files had been deleted but that update hadn’t happened yet. But that’s another problem.
