sorry for the possibly dumb question:
I have 3 machines, A, B and C.
A has a send-only folder and it’s remote.
B and C are on the same lan and are both receive-only.
Note that all three machines share the folder with the other 2 (e.g. B shares with A and C).
On purpose, I kept C turned off for a while; when I turned it on, I noticed it was downloading 90% from A and 10% from B, which seems a bit counter-intuitive.
In the GUI, B is displayed as “address: 192.168.8.x:22000”
Is there any setting I should enable to make local connections preferred?
Syncthings’s goal is to get data as fast as possible.
If your goal is “only send data over the internet to my lan once”, then make sure that there is only a single device sharing the folder with the device on the internet.
