Please pls help me write my ignore
// ignore all directories except for above
// do not exclude txt
(?i)!**.{md,txt}
// ignore .trash
.trash
This doesn’t ignore anything, and I’m not sure which part went wrong
My goal:
  • sync only text file (except for text file in .trash)
  • do not sync anything in .trash
thanks a great lot in advance
The order does matter, so you probably want:
(?i)!*.{md,txt}
The two ** are also redundant. They are only needed when you have patterns like directory/*/file and directory/**/file, which will match different contents. In addition, * already matches everything, so there is no need for a separate .trash entry above it.
thank you so much! But I realize I made a mistake in my post. What I actually meant is
My goal:
  • sync only text file (but not the text file in .trash)
This ignore provided seems to sync the text file in my .trash, which is not what I wanted.
(?i)!*.{md,txt}
Could you also explain how order matters in ignore? I can’t seem to find it in the official document
@tomasz86
Basically, if a previous patterns matches something already, then you cannot “unignore” it afterwards. This is why if you put * first, then everything gets ignored at the very beginning and you’ve got nothing to work with anymore.
Taking .trash into account, you probably want this then:
// ignore .trash
.trash
// do not ignore md and txt
(?i)!*.{md,txt}
// ignore all except for above
thanks a lot! @tomasz86
The second sentence in that paragraph tells you the order is important.
The first pattern that matches will decide the fate of a given file.
This sentence?
Think of an Ignore Pattern as being like an access list in this regard:
The file is evaluated by the first line in the Ignore Pattern. If there’s a match (whether it’s to ignore or to unignore), the action is taken and the ignore process exits: in other words, further lines in the Ignore Pattern file are not evaluated for that file.
This continues, line by line, until there is a match. The action is taken and further lines are not evaluated.
The final, “implied” line of the Ignore Pattern is to allow everything.
thanks a lot!
