The wikipedia is kind of outdated.
I think I’m prohibited from touching it as that would be original research.
Does look a little bare. Certainly not enough of Syncthing’s usefulness on show.
There was that article about Syncthing having no theoretical attack vectors.
Is that what you had in mind?
Or more details for the generally curious / click wanderers ?
This would fit into the paragraph about security as a reference.
That piece you referenced from wikipedia is what is presented usually when searching google with ‘define:xy’ (maybe only popular keywords).
I can’t contribute to the Go development, Wiki & Documentation can be my thing so.
I’m away for the next two weeks but I’ll add to it when I’m free, and I’ve an ARM + Syncthing guide I promised in the comments to get around to.
So sign me up
I added a little blerb in the technology section. Feel free to fix if it’s wrong.
