Hi, there is all sorts of explanations for this, but I can’t quite figure it out: why is it that the upload pictures folder (which is send only) from the pone always shows 95 or 99%, but not 100%? I would be very grateful for a simple explanation and answer if this is normal. Thanks.
My guess would be that there are photos that have been deleted on the other side, which is not applied on the send-only side. Or, possibly, other changes like metadata.
Sure, sooner or later you clear out the gallery on the phone to save space and the photos remain in the receiving folder. If that is the explanation, I’m good with it. Thanks.
