Using OpenMediaVault v3.0.88 (Erasmus),
openmediavault-syncthing 3.10 plugin, Syncthing v0.14.38, Linux (64 bit).
Added a folder “0_internal” and I see:
Error folder path missing
I checked through SSH, that the directory exists, owner is my user, permission is rw for my user.
I also changed GUI username & password in advanced settings through GUI. However entering username & password for GUI pops up the authentication window again & again.
But somehow later I entered into the GUI.
When restarting the Syncthing I get the following error log:
The plus sign after the permissions means there is also a custom ACL applied. Whether that’s a problem or not I can’t say, but it can theoretically override the more common permission bits. Use getfacl or something to take a peek.
and we’re now looking at the permissions of /srv/mydrive/Backup/MOBILE/myuser which is deeper into the hierarchy and irrelevant. So I’m guessing something changed in between.
In the end, this is a permissions problem. Try to do what Syncthing is doing, as the same user on the same machine, and see what happens.
