Hi there,
Just hoping someone might be able to help clarify how Syncthing manages the announcements of partially downloaded files. I have tempindexes enabled but for some reason if a peer has a large (60GB+) file, the other peers will only ever download from that specific peer, even though other peers may have almost half the file at that point. Once any other peers finish completely downloading it, they become a source for the others and everything speeds up. I’ve probably not explained that particularly well.
I have 6 peers, all on the same hardware (Intel based NAS, 6-bay RAID, Debian Buster, Syncthing 1.18.1). Config is pretty standard, only non-standard change is setting envvar to limit Go usable CPU cores to 2.
Does Syncthing announce partial files using the same RemoteIndexUpdated event as with full files? Is there any other config options that may affect whether partial downloads are seeded? These are the ones I could find that may affect this:
<order>random</order>
<disableTempIndexes>false</disableTempIndexes>
<blockPullOrder>standard</blockPullOrder>
<copyRangeMethod>standard</copyRangeMethod>
<tempIndexMinBlocks>10</tempIndexMinBlocks>
Any help or clarification would be greatly appreciated Thanks! Jon
