Using 1.6.1 on a Mac. Shorty after the startup Syncthing has issues.
I reinstalled Syncthing. Config was still available, reinstall did not help. I then deleted the DB files. Rescan and all seemed to be fine then. 3 hours later same starts again.
Attached the log (sorry, I had to replace github.com by githubcom, otherwise I cant send), any hints maybe?
Thanks in advance!
=== [start] 19:57:52 INFO: syncthing v1.6.1 “Fermium Flea” (go1.14.4 darwin-amd64) teamcity@build.syncthing.net 2020-06-02 09:49:22 UTC
Panic at 2020-06-13T19:58:19+02:00 panic: runtime error: index out of range [1] with length 1
goroutine 98 [running]: githubcom/syncthing/syncthing/lib/model.(*sendReceiveFolder).processNeeded(0xc0001b6380, 0xc000041a80, 0xc000959da0, 0xc000959ce0, 0xc000959c20, 0xc000959da0, 0xc000959c20, 0x4e261c0, 0xc0006b9c90, 0xc00285d520, …)
… a lot more and ending with
/Users/syncthing/agent/work/174e136266f8a219/lib/model/folder_sendrecv.go:247 +0x49 created by githubcom/syncthing/syncthing/lib/model.(*sendReceiveFolder).pullerIteration /Users/syncthing/agent/work/174e136266f8a219/lib/model/folder_sendrecv.go:245 +0x4a9
goroutine 425 [chan receive]: githubcom/syncthing/syncthing/lib/model.(*sendReceiveFolder).copierRoutine(0xc0001b6380, 0xc000959ce0, 0xc000959c80, 0xc000959d40) /Users/syncthing/agent/work/174e136266f8a219/lib/model/folder_sendrecv.go:1193 +0x476 githubcom/syncthing/syncthing/lib/model.(*sendReceiveFolder).pullerIteration.func2(0xc0001b6380, 0xc000959ce0, 0xc000959c80, 0xc000959d40, 0x4e261c0, 0xc0006b9c80) /Users/syncthing/agent/work/174e136266f8a219/lib/model/folder_sendrecv.go:247 +0x49 created by githubcom/syncthing/syncthing/lib/model.(*sendReceiveFolder).pullerIteration /Users/syncthing/agent/work/174e136266f8a219/lib/model/folder_sendrecv.go:245 +0x4a9
goroutine 424 [select]: githubcom/syncthing/syncthing/lib/model.(*sendReceiveFolder).dbUpdaterRoutine(0xc0001b6380, 0xc000959da0) /Users/syncthing/agent/work/174e136266f8a219/lib/model/folder_sendrecv.go:1614 +0x238 githubcom/syncthing/syncthing/lib/model.(*sendReceiveFolder).pullerIteration.func1(0xc0001b6380, 0xc000959da0, 0x4e261c0, 0xc0006b9ca0) /Users/syncthing/agent/work/174e136266f8a219/lib/model/folder_sendrecv.go:239 +0x35 created by githubcom/syncthing/syncthing/lib/model.(*sendReceiveFolder).pullerIteration /Users/syncthing/agent/work/174e136266f8a219/lib/model/folder_sendrecv.go:237 +0x414
goroutine 3829 [select]: net.(*netFD).connect.func2(0x4e28c00, 0xc0038b80c0, 0xc0038cc280, 0xc0063af980, 0xc0063af920) /Users/syncthing/sdk/go1.14.4/src/net/fd_unix.go:129 +0xba created by net.(*netFD).connect /Users/syncthing/sdk/go1.14.4/src/net/fd_unix.go:128 +0x22f
